8th Gen 2006 - 2011.
Fuse continues to blow
Old 11-21-2013
happybilmore's Avatar
happybilmore is an unknown quantity at this point
Hello all
proud 2007 owner here.
My front power accessory outlet fuse keeps blowing. I have to replace it frequently.
Any ideas as to why?
I have used the same phone charger in it for years.
I can say I did notice the problem started occurring after I used a air pressure inflation that was above the recommended volts. That said I haven't used it since.
FUSE 29 -15a
happybilmore is offline
Old 11-21-2013
Re: Fuse continues to blow
Which fuse, and which socket?
See if there is anything still in the bottom of the socket. Check both of them (if you have two).
Numerous times I've seen where someone has their accessory plug fall apart and they don't get all the pieces out of the socket.
ezone is offline
Old 11-21-2013
CraigW's Avatar
Yes, look it over inside and also look for damage from overheating when the compressor was used.
The improved later sockets have the dished out center terminal.
CraigW is offline
Old 11-21-2013
07 is supposed to have the improved version from the factory.
ezone is offline
Old 11-22-2013
thanks; should have a look in there tomorrow or Saturday weather pending. I'll post again.
mjdiaz89
06-21-2016 09:26 PM
MrOldskool
08-18-2015 09:58 AM
Dave1984
07-22-2015 06:10 PM
Civic65
07-19-2015 10:13 AM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
Quick Reply: Fuse continues to blow
