8th Gen 2006 - 2011.
my car makes a rubbing noise when starting from a dead stop
Old 04-28-2013
tmillones's Avatar
tmillones is an unknown quantity at this point
i bout a used 2007 si and when starting from a dead stop i hear a low rubbing noise. Help me please
tmillones is offline
Old 04-29-2013
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: my car makes a rubbing noise when starting from a dead stop
Could you be more specific? From where, what side of the car, front or back, could be the wheel wells, underspoiler, lots of things..
Gunner is offline
Old 04-29-2013
Prelude Owner
GolNat's Avatar
Yea that's a little to general. Does it sound rotational (gets louder as you go faster)? Does it go way when you stop or steer?
Are you modified? Lowered, aftermarket wheels? Was any maintenance done recently?
GolNat is online now
Old 05-02-2013
tmillones's Avatar
ya i realized, sorry. i bought it with a pucked clutch? good or bad? i am so clueless on these its the first time i heard of it. the noise stops after i get going. its there whether i start in 1st or 2nd and as aftermarket goes only wheels and thats about it except for exhaust which is irrelevant.
Old 05-02-2013
Gunner's Avatar
It is from the front or back? Not sure what a pucked clutch is unless you mean something else...
still could be a million things the way you descrive it... how are your brakes? are they worn in the front bad?
Gunner is offline
Old 05-02-2013
tmillones's Avatar
i guess its some sort of race clutch designed for hard launches. if i wouldve known this prior probably would have avoided it since i live in orange county where red lights are plentiful. the noise is in the front and when i rev around 2-2.5 k and drop the clutch its totally fine and no noise is made just when riding the clutch in parking lots when backing up and such.
Old 05-03-2013
Gunner's Avatar
ok, well i would check for a couple things, check your wheel wells and make sure the plastic is not hanging or loose at all, have someone turn the wheels left and right and make sure they dont rub at all, Check the inside of your tires and see if they are showing signs of rubbing. Then check your supspension and other stuff like your CV boots, make sure they are not cut or leaking..
Gunner is offline
CarStuff
12-06-2020 12:52 PM
McD
04-29-2015 03:50 PM
Linda0818
04-23-2015 11:30 AM
twtron
04-17-2015 12:09 AM
SSMatey
04-13-2015 06:09 PM
Quick Reply: my car makes a rubbing noise when starting from a dead stop
