how to deal with this tranmission headache?
Rep Power: 0 how to deal with this tranmission headache?
We just bought a used Honda 2006 civic from a local dealer three months ago. Today we sent the car for a routine maintenance. A mechanic accidentally fount out there was a crack on the transmission case. Someone fabricated a plate to hold the transmission case together. In doing so they used a longer bolt and tighten it too tight causing it to bend. The case was damaged more at the area the bolt goes through at that point. Now the transmission fluid is leaking from the case.
I don't when the crack happened and how long the transmission case has been leaking fluids.
The mechanics recommended replacing the transmission. The dealer only wanted to replace the transmission case. The car is still drivable. But I don%u2019t know how bad the transmission is since the fluid is leaking.
What is your advice? And how much it will cost to rebuild the transmission if it has to?
Touge
09-23-2015 11:19 PM
Touge
Ottawa
09-23-2015 11:14 PM
Touge
09-22-2015 11:55 PM
Touge
Ottawa
09-22-2015 11:52 PM
Touge
09-22-2015 11:52 PM
