My '09 Civic Si calls for 91 octane or higher....Why??
Rep Power: 0 My '09 Civic Si calls for 91 octane or higher....Why??
Someone told me the other day that it makes no difference . He drives an Acura MDX which is supposed to take 91+ and he is running 87 and says he notices no difference whatsoever.
I figure the folks at Honda have a reason why I'm supposed to run 91+, so I do it.
But why ?
But why ?
Received 1,148 Likes
Rep Power: 485 Re: My '09 Civic Si calls for 91 octane or higher....Why??
Higher compression ratios require higher octane gas. Your Civic has a K20Z3 which has a compression ratio of 11:1
From my understanding, and someone, please correct me if I'm wrong, higher octane fuels burn at higher temperatures, thus being safer for high compression or forced-induced (turbo, supercharger, NO2) engines. The thing it's trying to prevent is detonation, or pre-mature (i.e. not spark plug induced or the diesel effect) ignition of the air/fuel mixture in the cylinder.
Whachya lookin at?
Rep Power: 289 Re: My '09 Civic Si calls for 91 octane or higher....Why??
I think your right Josh. The premature detonation (hah) causes the engine to knock. That's how you can tell its happening. You can try to put 89 in it ... if you can't hear a knock you should be okay.
I'd rather spend the extra 20 cents per gallon than take the chance. That's just me.
Received 1,442 Likes
Rep Power: 338 Re: My '09 Civic Si calls for 91 octane or higher....Why??
then spark plug ignites and you have one fire front coming from premature ignition and another coimng from the spark plug.
when they approach each other, the pressures in between them will be monstruous.
when they hit one another, well, it will skyrocket. temperatures will also. it will eventually open a hole in the engine. temps are higher than some components melting point, BTW.
that's detonation.
do you want to risk it?
Whachya lookin at?
It sure can... even if its off a little bit it wears components down prematurely. I was just looking at 2012 Si's, and it's one thing that really turns me off of them.
LionSpratt
01-29-2017 11:07 PM
ScottyEj8_DB7
04-26-2015 04:07 PM
cooldan1
04-23-2015 10:49 AM
vtechcivic
04-21-2015 06:58 PM
