Vibration at idle, only for a few seconds
2006 Honda civic Sedan, lx.
When I am idling in park sometimes I get a strong vibration for a few seconds...
After the few seconds it goes away, and a minute or two later it MIGHT do it again, although sometimes it takes several minutes between vibrations.
I was wondering if anyone else had this?I'm not particularly worried about it as it doesnt seem to be anything that could hurt the car, I was just interested to see if this is normal, or if there is something "up" with my civic.
It is NOT the alternator turning on, that happens when I am idling with the A/C on and I hear a "click" before hand, what I am talking about is just a vibration out of nowhere, without any see-able cause and without any recognizable pattern.
EDIT: also SHOULDN'T be my gas, I use the local shell station, which is listed as a top tier gas provider here:http://www.toptiergas.com/retailers.html
Dr Krieger of Modification
Re: Vibration at idle, only for a few seconds
do you have any mods?
are you keeping up on maintenance (plugs, filters, battery, oil)?
are there any lights on like the CEL?
have you done an idle re-learn?
Nope, all stock.
I keep up with my oil and check my filter, plan on doing plugs around 100k(I'm at 60k)
No.
A wha?
EDIT: Found this after a google search, is this all there is to it?
"Remove fuse #6 from the fuse box under the hood. Wait a minute, then reinstall it. (or just disconnect the battery)
With everything electrical turned off (radio, wipers, heat/ac, etc.) - Start the car and hold the idle at 3,000 RPM until the radiator fan comes on.
Release the accelerator and let the car idle for five minutes. (not including the radiator fan run time)"
EDIT2idn't say what honda vehicle this was for, does this work/ do the 8th gens have a fuse box under the hood? where is it?
Nope, all stock.
No.
A wha?
Under the hood. Duh.
Maybe this would help you locate the fusebox:
/Yeah, I feel like being an *** again today.
//This was mild.
///Time to go for a ride.
Ok, seriously.....
Does the engine RPM change or drop when the vibration happens?
Do the headlights dim a little bit when this happens?
Is it a noise?
(where? what? How would a blind person find the noise?)
Is it a shake?
Have you watched what is going on in the engine compartment when this happens?----Like, is the AC kicking on and off, or are the radiator fans coming on when this happens?
//This was mild.
Ok, seriously.....
Is it a noise?
Is it a shake?
Yes, it drops for a sec, then goes up, then goes back down.
I have not checked.
Is it a noise?
No, no noticeable noise.
Is it a shake?
Yes, after the revs drop the car shakes/virbates for a few seconds, then the rpms go up higher than they were before, then slowly drop back down.
No
Ac is not on, so I hope not
I don't think so, I usually hear when they go on.
I have not checked.
Is it a noise?
Is it a shake?
No
Try an idle learn first.
Get the engine fully warmed up.
Turn off all electric loads.
Let it idle for 10 minutes.
See if that improves anything.
This may need done any time the battery dies or gets disconnected.
Then:
Ok, I found a TSB for a software reflash.
Honda Service Bulletin 10-073
If you think this matches your symptoms, you will need to go to a dealer for this.
Couldn't find a PDF right away, but this looks like a word for word copy of the info: http://www.8thcivic.com/forums/mecha...ml#post9791193
Applies To:
2006-08 Civic with R18A1 Engine - ALL
Intermittent Engine Vibration At Idle When At A Stop
SYMPTOM
The driver feels an intermittent engine vibration when the vehicle is stopped and idling with various electrical systems on.
PROBABLE CAUSE
The PGM-FI software is slow to respond to engine load because of varying electrical loads.
CORRECTIVE ACTION
Update the PGM-FI software with the HDS.
HTH
Then:
Applies To:
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
HTH
Then:
Applies To:
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
HTH
Then:
Applies To:
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
HTH
How do I do a transmission re-learn, is it what I saw on the other site:
Is that all there is to it?
Holding at 3000 is only to get it warmed up, you can do the learn at any time the engine is warm.
All there is is idle and CKP learns for the engine, and the CKP should never need done unless the CKP sensor or crank or block is replaced. The CKP would need done with the HDS or an equivalent scanner.
The idle learn is all you can do yourself. My info says 5-10 minutes.
HTH
I never do, but most of the learns I do are on new cars or from dead batteries.
Occasionally with service work that could affect idle.
I also don't really do them if the scanner says it has already been learned unless there is a problem with the way it idles.
On new cars, I do the check in, gas it up, take it for a drive, then come back to the shop and let it idle while I do my paperwork (or eat lunch, or whatever). Learn is completed by the time I'm done.
It just needs to idle with no loads and nothing touching the gas pedal.
Radiator fans are an electric load, so the time with those running does not count toward the 5 minutes.
HTH
HTH
My car door had to be worked on a while back, and again it was at a shady place because of my parents...
Regardless, I know they disconnected the battery because I had to enter my radio code, therefore I'm pretty sure they didn't do a re-learn, and I almost always have my subwoofers or AC on...so I'm pretty sure it has never had the chance...
So if i drive it for a while, then park it and turn everything off and let it idle, with that do the trick? Or should I remove the fuse 6 beforehand?
Go ahead and pull it just to be sure, or disconnect the battery.
I don't, but I can watch the scanner. You don't have that option.
Ok,thanks for the help...I'm actually gonna do this tomorrow morning after I get back from school, car should be warmed up by then(15 minutes drive,mostly highway at 70mph)
1khilari
07-09-2015 08:12 PM
ballmich
07-09-2015 11:59 AM
CivicsClass101
07-09-2015 11:14 AM
cgavin1
07-07-2015 07:10 AM
