8th Gen 2006 - 2011.
SRS Light
Old 03-26-2012
siukityu211's Avatar
siukityu211 is an unknown quantity at this point
SRS Light
Hi all,
My SRS light begins to go on once in a while, usually after a bump on a road/ freeway. Yet it stops after I restarts the engine. Does anyone know what happens in this situation? How much would it take to fix?
Thanks a lot!
siukityu211 is offline
Old 03-26-2012
Re: SRS Light
The price will START with a fee for diagnosing it.
THEN an estimate can be made, once someone knows what the problem is and what it will take to fix it.
You have this under 8th and 9th gen, that covers 2006 and newer.
Pretty broad range there, slim.
Come on, we aren't psychic.
Got nuthin.
Red light or yellow light?
You must start with getting the fault code, that will describe what fault is causing the light to be on.
Autozones code readers cannot help you.
Your symptoms describe a (likely) circuit fault, and are probably related but will be of minimal use until we know what the code is and what it stands for, and which one of the several dozen circuits is in question. It will be handy information for whomever gets to diagnose your problem, so make sure this info gets to that person.
HTH
ezone is offline
Burnout
07-15-2022 10:24 PM
Blazz
05-25-2015 10:56 PM
cukaracha
05-16-2015 02:11 PM
XtremelySpoiled
12-13-2001 08:47 PM
SimDogg
11-27-2001 04:20 PM
Quick Reply: SRS Light
