2012 Civic lauched specs are up in their website
Received 1,440 Likes
Rep Power: 338 2012 Civic lauched specs are up in their website
I forgot to post this yesterday when i got a call from the dealer - they will be launching the new 9th gen civic tomorrow.
Finally this forum will start having real owners, not lost guys posting in the first forum they see...
follow the Si...
less power, more torque, no more high rev...
The body seems to have had slight modifications since the protos?
Coupe seems more fluid?
http://automobiles.honda.com/civic-s...fications.aspx
Engineering
Si
Engine Type In-Line 4-Cylinder
Engine Block/Cylinder Head Aluminum-Alloy
Displacement (cc) 2354
Horsepower @ rpm (SAE net) 201 @ 7000
Torque (lb-ft @ rpm) 170 @ 4400
Redline (rpm) 7000
Bore and Stroke (mm) 87 x 99
Compression Ratio 11.0 : 1
Valve Train 16-Valve DOHC i-VTEC®
Stainless Steel Exhaust Manifold Standard
Multi-Point Fuel Injection Standard
Drive-by-Wire™ Throttle System Standard
Front-Wheel Drive Standard
CARB Emissions Rating ULEV-2[1]
Direct Ignition System with Immobilizer Standard
100K +/- Miles No Scheduled Tune-Ups[2] Standard
Transmissions
Si
Close-Ratio 6-Speed Manual Transmission Standard
Gear Ratios: 1st: 3.267, 2nd: 2.040, 3rd: 1.429, 4th: 1.073, 5th: 0.830, 6th: 0.647, Reverse: 3.583, Final Drive: 4.76
Helical Limited-Slip Differential Standard
Body/Suspension/Chassis
Si
Unit-Body Construction Standard
MacPherson Strut Front Suspension Standard
Multi-Link Rear Suspension Standard
Stabilizer Bar (mm, front/rear) 18.0 / 15.0
Motion-Adaptive Electric Power-Assisted Rack-and-Pinion Steering (EPS) Standard
Steering Wheel Turns, Lock-to-Lock 3.11
Steering Ratio 16.08
Turning Diameter, Curb-to-Curb (ft) 35.4
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes 11.8 / 10.2
Wheels 17" Alloys
All-Season Tires P215 / 45 R17 87V
Michelin® Pilot® Exalto® PE2™ Summer Tires (available)[3] 215 / 45 ZR17 91W
Compact Spare Tire T135 / 80 R16 101M
Exterior Measurements
Si
Wheelbase (in) 103.1
Length (in) 176.1
Height (in) 55.0
Width (in) 69.0
Track (in, front/rear) 59.0 / 59.9
Curb Weight (lbs) 2877 / 2897 (with Navigation)
Weight Distribution (%, front/rear) 61 / 39
Interior Measurements
Si
Headroom (in, front/rear) 37.7 / 34.3
Legroom (in, front/rear) 42.2 / 30.8
Shoulder Room (in, front/rear) 55.1 / 52.2
Hiproom (in, front/rear) 53.2 / 49.0
Cargo Volume (cu ft) 11.7
Passenger Volume (cu ft) 82.6
Seating Capacity 5
EPA Mileage Estimates[4] /Fuel
Si
6-Speed Manual (City/Highway/Combined) 22 / 31 / 25
Fuel (gal) 13.2
Required Fuel Premium Unleaded
Safety
Si
3-Point Seat Belts at all Seating Positions Standard
Front 3-Point Seat Belts with Automatic Tensioning System Standard
Driver's and Front Passenger's Seat Belt Reminder Standard
Dual-Stage, Multiple-Threshold Front Airbags (SRS) Standard
Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS) Standard
Side Curtain Airbags Standard
Advanced Compatibility Engineering™ (ACE™) Body Structure Standard
Vehicle Stability Assist™ (VSA®) with Traction Control[5] Standard
Brake Assist Standard
Anti-Lock Braking System (ABS) Standard
Electronic Brake Distribution (EBD) Standard
Tire Pressure Monitoring System (TPMS)[6] Standard
Daytime Running Lights (DRL) Standard
Side-Impact Door Beams Standard
Lower Anchors and Tethers for CHildren (LATCH):
Lower Anchors (2nd-Row Outboard), Tether Anchors (2nd-Row All) Standard
Child-Proof Rear Door Locks
Emergency Trunk Release Standard
Exterior Features
Si
One-Touch Power Moonroof with Tilt Feature Standard
Integrated-Rear Window Antenna Standard
Security System with Remote Entry with Trunk Release Standard
Body-Colored Power Side Mirrors Standard
Variable Intermittent Windshield Wipers Standard
Body-Colored Decklid Spoiler Standard
Chrome Exhaust Finisher Standard
Impact-Absorbing Body-Colored Bumpers Standard
Multi-Reflector Halogen Headlights with Auto-On/Off Standard
Fog Lights Standard
Body-Colored Door Handles Standard
Comfort & Convenience
Si
Air Conditioning with Air-Filtration System Standard
Honda Satellite-Linked Navigation System™ with Voice Recognition and FM Traffic[7] Available
Bluetooth® HandsFreeLink®[8] Standard
Power Windows with Auto-Up/Down Driver's Window Standard
Power Door Locks with Auto-Lock Feature Standard
Illuminated Driver's Window and Door Lock Controls Standard
Cruise Control Standard
Leather-Wrapped Steering Wheel Standard
Aluminum Shift **** with Leather Standard
Textured Aluminum Pedals Standard
Illuminated Steering Wheel-Mounted Controls Cruise / Audio / Phone / i-MID / Navi (available)
Tilt and Telescopic Steering Column Standard
Beverage Holders Front and Rear
Center Console with Armrest and Storage Compartment Standard
Front Door-Pocket Storage Bins Front
Passenger-Side Seatback Pocket Standard
Coin Tray Standard
Remote Fuel Filler Door Release Standard
Remote Trunk Release with Lock Standard
Headlights-On Reminder Standard
Driver's and Front Passenger's Vanity Mirrors Standard
Map Lights Standard
Rear-Seat Armrest Standard
Rear-Seat Heater Ducts Standard
Floor Mats Standard
Driver's Footrest Standard
12-Volt Power Outlet Front and Center Console
Rear Window Defroster with Timer Standard
Cargo Area Light Standard
Seating
Si
Driver's Seat with Manual Height Adjustment Standard
Adjustable Front Seat-Belt Anchors Standard
Reclining Front Seatbacks Standard
Adjustable Head Restraints Standard
Fold-Down Rear Seatback 60/40 Split
Audio Systems
Si
360-Watt AM/FM/CD Premium Audio System with 7 Speakers including Subwoofer Standard
XM® Radio[9] with Navigation
USB Audio Interface[10] Standard
MP3/Auxiliary Input Jack Standard
MP3/Windows Media® Audio (WMA) Playback Capability[11] Standard
Radio Data System (RDS) Standard
Speed-Sensitive Volume Control (SVC) Standard
Instrumentation
Si
12-Volt Battery Charging System Indicator Standard
ABS Indicator Standard
Airbag System Indicator Standard
Brake System Indicator Standard
Coolant Temperature Indicators Standard
Cruise Control Indicators Standard
Digital Speedometer Standard
Door and Trunk Open Indicators Standard
DRL Indicator Standard
Electric Power Steering (EPS) Indicator Standard
Fuel Level Indicator Standard
Headlight-On Indicator Standard
High-Beam Indicator Standard
Immobilizer System Indicator Standard
Low Tire-Pressure Indicator Standard
Low-Fuel Indicator Standard
Low-Oil Pressure Indicator Standard
Maintenance Minder Indicator Standard
Malfunction Indicator Standard
Passenger-Side Side Airbag-Off Indicator Standard
Red Backlit Gauges Standard
Seat Belt Reminder Indicator Standard
Security System Indicator Standard
System Message Indicator Standard
Tachometer with Sequential Rev-Limit Indicator Standard
TPMS Indicator[6] Standard
Turn Signal/Hazard Indicators Standard
Two-Tier Instrument Panel Standard
VSA System and Off Indicators Standard
Washer Fluid Level Indicator Standard
intelligent Multi-Information Display (i-MID)
Si
Average Fuel Economy Indicators Standard
Average Speed Indicator Standard
Clock Standard
Customizable Door Lock Settings Standard
Customizable Interior Light Settings Standard
Customizable Language Settings Standard
Customizable Screen Color Settings Standard
Customizable Wallpaper Settings Standard
Digital Fuel-Mileage Indicators Standard
Digital Odometer and Digital Trip Meters (2) Standard
Elapsed Time Indicator Standard
Exterior Temperature Indicator Standard
FM Traffic with Navigation
Maintenance Minder™ System Standard
Miles-to-Empty Indicator Standard
Power Monitor Screen Standard
Turn-By-Turn Directions with Navigation
Welcome Screen Standard
follow the Si...
Engineering
Si
Redline (rpm) 7000
Transmissions
Si
Si
Wheels 17" Alloys
Si
Length (in) 176.1
Height (in) 55.0
Width (in) 69.0
Si
Seating Capacity 5
Si
Fuel (gal) 13.2
Safety
Si
Exterior Features
Si
Fog Lights Standard
Si
Coin Tray Standard
Map Lights Standard
Floor Mats Standard
Seating
Si
Audio Systems
Si
Instrumentation
Si
Si
Clock Standard
Rep Power: 338 Re: 2012 Civic lauched specs are up in their website
posted some of the info in the official website
And it is a good way to keep the records for 15 years in the future
I am actually having a hard time to find more info on the official sources on the 7th gen...
I'm impressed with the the 31 more torques that the engine has and it makes them at 4400 revs. I'm not impressed with the 201 HP at redline. 8th gen Si made their peak power a few hundred revs before the redline. I'm also not impressed with the gas pedal, it was floor mounted in the 8th gen Si. Other than that, I think it's alright. I'd still get a WRX for the same amount of money though.
Just saw a first drive video of the Si coupe. You can't put an aftermarket exhaust header on it because the stock manifold goes right into the cylinder head. I'm not sure on what that means, but the the guy who was doing the video said that. I'm sticking with my 8th gen si.
I will just bump this, so hopefully the desperate idiots that post anywhere they please will see that this forum is for 2012 civics...
Trance Addict
A little more info for those interested:
http://www.autoblog.com/2011/04/20/2...-drive-review/
Lol @ the memebait line.
Rep Power: 176 Re: 2012 Civic lauched specs are up in their website
i like the inside of the car, specially the dash with vtec light that was carry over from the jdm civic type r, they lost the heritage of what a high performance honda sport should be,
high rev 8k rpm redline, with this one you only getting up to 7 and vtec engaged at 5500 rpm, that only gives you 2500 rpm of fun then shift. i wan't to see the car in person with honda full HFP kit then i make my final judgment. I gues i will be keeping my 6th gen si and wait for toyota rwd sport compact that will be coming out soon
Rep Power: 223 Re: 2012 Civic lauched specs are up in their website
I dont know if im feeling it either. I'm going to have to see one in person. To me the back end looks like the Accord Coupe sorta. However, im feeling the interior though. Nice and spiffy!
Today i went to several alignment shops to find a place to align the car. Bummer, these "need an appointment" stuff in Canada is kind of annoying...
Ended up in Honda dealer, hope they will do a good job... (wishful thinking...).
Anyway, there was one 2012 there.
No wonders, i looked around the car, some details different, but first chance i got, i looked under the car... (who would have tought i would do that? )F/R configuration seems to be similar to 8th gen, but could not hang in there too long, too many guys in there after the launch...
There was a plastic cover underneath the chassis, too (same as the hybrid?)
And some odd metal reinforcement? or just to hold the plastic cover? attached to the rear sub-frame? WTF?
bump for 2012 vics showing on the top in the forum... Another one came posting a 2002stuff
The new Si uses the I-vtec engine just like the old one. So vtec should kick in as soon that you stomp on the pedal and not at a set rpm like older models do.
I build these civics everyday and I can say that honda is trying to keep up with hyundai who seems to buy their customers with gadgets. Honda seems to have cheaped out on this gen to keep up with hyundai. It is still a very good car and you get what you pay for and I still believe that the new model is still the better "Affordable" car on the market but its not like previous gen's. 8th Gen civic was better built imo.
bump AGAIN... Another 2 desperate idiots that think they have 2012 vics to posted in this 9th gen forums yet again...
another bump because the idiot posted again asking "where do i post about the 2006?"
I own an 8th gen Si. I smile every time I hear it go into VTEC at 6000 revs. This 9th gen Si has a light to tell you when you hit VTEC. Why? That is because you can no longer hear VTEC kick in. I frown when that happens.
another bump. 2 more guys that need to buy glasses to read the answers when they do post in the right section... Siiigh...
Bad eyesight members count going up and up.
Jon-Ohio
06-30-2018 08:10 PM
