8th Gen 2006 - 2011.
radiator upper hose
Old 12-16-2010
liuxinbing's Avatar
liuxinbing is an unknown quantity at this point
radiator upper hose
My coolant is leaking at the spot where the upper hose meets the radiator. I have to add half litre of coolant every week. The upper hose connector is the only place leaking.
Do I have to remove the bulkhead cover to gain access to the connector? Do I have to change the hose or just wipe out debris on and around the connector and re-insert the hose?
The clamp is rusted and can't be reused. Can I use an universal stainless steel hose clamp shown in the picture?
I bought my 06 Civic coupe then found this problem. Thanks to everyone for looking.
Name:	hose clamp SS.jpg
liuxinbing is offline
Old 12-16-2010
lazlong's Avatar
Re: radiator upper hose
You shouldn't have to move anything to get to the clamp. If the hose is undamaged then clean and re-use it. Universal clamps will work fine, I have several on my car. You can almost buy a whole package for the price of one clamp from Honda.
lazlong is offline
Old 12-16-2010
liuxinbing's Avatar
Thanks.
I had no access to the clamp because it's under a steel protecting plate. To remove it, I had to first remove the plastic cover by prying the clips (C). Unfortunately I broke the plastic clips(C) when prying.
Is there any special skills to safely pry out the plastic clips?
Old 12-16-2010
Mad Dog Tannen's Avatar
I would cut off the old squashed part of the hose and reuse the rest. Those clamps will work fine.
Mad Dog Tannen is offline
Old 12-16-2010
lazlong's Avatar
Pry up on the middle part with a flathead. You'll end up breaking some. When I'm gonna be taking those body pins out I go buy a box or two at the auto parts store.
lazlong is offline
Old 12-16-2010
liuxinbing's Avatar
good point! I will buy a dozen clips from CarQuest.
USCGBM
08-12-2015 04:22 PM
mrwhos
08-11-2015 02:03 AM
Tdmnds
08-05-2015 04:23 PM
liagreenhalgh92
07-21-2015 01:31 PM
silentz
07-09-2015 08:16 PM
Quick Reply: radiator upper hose
