Filled in Diesel instead of Gas
Rep Power: 0 Filled in Diesel instead of Gas
Hi,
I have 09 Civic
I happened to fill diesel into the car instead of gas. I filled about 2 gallons and then I realized that i was filling diesel. The car already had about 2 gallons gas. I got scared and drove off.
Can anyone tell me what do I do next? One option I could think off was drain off all the fuel from my car then fill it entirely with gas so the remaining traces of diesel will get diluted. This is what I heard but I am not sure if this would be right way..
Can someone please help me out?
I have 09 Civic
Canadian, Eh!
Rep Power: 252 Re: Filled in Diesel instead of Gas
Holy crap, I find it hard to believe you drove off. I'd be surprised if you made it home.....or even out of the parking lot.
Anyway, if this isn't a joke, you HAVE to siphon the gas out of your tank. Stick a hose in there, suck on the other end and let it all drain out.....all of it. Have a friend take you to the gas station to fill up a container and bring it back to fill your tank FULL....all the way up. Your timing may be off a little with the combustion on the last bit of diesel but it should work itself out.
Hi,
I have 09 Civic
I have 09 Civic
Rep Power: 0 Re: Filled in Diesel instead of Gas
Thanks for your prompt replies and suggestions
I don't know how I manged to insert the diesel nozzle inside the tank. Probably the car ran coz of the gas that was still inside..I did have some problems like the car would take some time to start once I stopped at a signal
Canadian, Eh!
They are at all the pumps I've used, I tried to put a diesel nozzle into my tank once and couldn't figure out why it didn't fit. Who knows what other small town gas stations use though.
Rep Power: 787 Re: Filled in Diesel instead of Gas
over here the diesel pumps look exactly the same and the nozzle is the same size too. they are just green colored handle instead of black. they are even sometimes right next to each other on the same pump. very common and easy to put diesel in. you shouldve towed the car home instead of driving it. i wonder if any diesel car owners have put regular gas inside? lol
Rep Power: 229 Re: Filled in Diesel instead of Gas
Over here in NY you have to hit a button that says 89 91 93 or whatever so its hard to screw up.
Some guy on youtube shows you what to do if this ever happens. Basically he uses the fuel pump and a piece of hose to pump the fuel out of the tank and into a bucket. He then just fills it with gasoline and lets the rest of the diesel burn off. Simple enough if you ask me. You need something to power the pump while the car is off. Id change the plugs after all the diesel is burned off.
if you need to burn something that normally wont burn, dump that diesel on it and it will burn. Thats how we burned POOP from our outhouses in Iraq.
Hi,
Yes I think I will try to siphon out the (gas+diesel) from the car and then fill the tank completely with gas.
But, I am a bit concerned as I drove my car so there are chances that diesel got into my car engine, so will that be a problem? And I am not sure actually how much got in. Any idea if this would screw up my car?
I also got in touch with a local mechanic who said He'll open up the engine and replace the filters. However, I am not sure if this required.
Also, my car is still under warranty but obviously they won't cover up for my stupidity. But, if I let the mechanic have my car fixed and since he would be replacing the filters etc., will it make my car warranty void?
lol engine filters? thats new to me. i dont think there are any lol. just take out the remaining stuff and fill it up with regular gas. drive it thru the whole tank and change the plugs, im sure it will be okay. any more problems later you can take it back for warranty cause they wont know it had diesel in it before.
jessica19699
07-29-2015 05:51 AM
07-12-2015 11:54 AM
