Rear Control arms, rear tire wear early models the early models had an issue with the rear control arms (upper) and have a tendency of rapid rear tire wear
Noise from tires while running
Old 04-03-2009
toronto1's Avatar
toronto1 is an unknown quantity at this point
Question Noise from tires while running
My 2007 Honda civic was very QUIET for almost an year. Then I started hearing noises that increase with speed, and I guessed it was from the tire. I thought it should go away when I changed to new snow tires last December. It didn't. Now I changed back to old All Season tires, and the noise seemed to increase.
I took the car to my Honda dealer today. The mechanic checked it out, took it for a drive, but could not pinpoint the source of this noise. He then checked the tires and the suspension and said, the Rear control arm need update and because of that, the tear tires got feather edged and that made the noise. The car has done only 52000 kms and the original Dunlop tires have done only 42000 kms.
Any comments or suggestions?
Old 04-03-2009
CraigW's Avatar
Re: Noise from tires while running
Most likely the tires are rated at around 40k miles.
If they are cupped or scalloped... they will never recover and will be noisey till the end.
Old 04-04-2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
well once they replaced the rear arms you should have no problems with your tires. just drive on and enjoy the silence. i know how noisy those tires can get.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
bsmiley
04-27-2015 01:27 PM
bo_red
04-23-2015 10:09 PM
klam
11-14-2001 03:45 PM
technosilver
11-14-2001 10:58 AM
Quick Reply: Noise from tires while running
