Is the R18 more then a base model motor?
#32
Rep Power: 275 Re: Sedan or Coupe
Ok i guess im not done.
wow... my car only makes 90whp stock, 273 is a BIG difference. Actually the difference is close to what you put down stock.
If you had a estimate for your power output that was more realistic then I would be more apt to believing you. Also you dont realize that supercharger belts get really hard to turn after 12 psi or so and you will have lots of slipping problems. You may want to look into a turbo if your going for seriously big numbers like that. A supercharger is better for low end power a turbo is better for high end.
#34
ooh ok. my point still stands. seriously do some research and if you got the cash to spend then the k20 is an awesome platform.
#35
Rep Power: 213 Re: Sedan or Coupe
yea but to get 100HP i dont even need ****ing boost for this? lawls!
P2r spacer
CAI
Full exhaust
Hondata reflash 25HP
Cams
i could go on.....
P2r spacer
CAI
Full exhaust
Cams
i could go on.....
#37
#38
I diddnt see a dyno graph, the reason he kept with the evo is because of weight. It even said in the vid stock k20 internals w/ stock ecu
#39
for **** sakes man!
the guy had 22PSI VS a ****ing stock K20 on stock internals and ECU
who cares!!
N/A WASTED BOOSTED......wnd of story, i care less about a ****in graph at this point dude.
who cares!!
#40
ok man but its not 300 HP N/A that car prolly weighs 2200lbs yours weighs 2900 you will need prolly 300 to 350 hp to make it that fast. Why did you want to see a graph from my car then if you could care less?
#41
i didnt believe you at the time thats all....i thought you were BSn me!
ahahah! cool ya got 300HP bruh'
but if i showed an OLD vid of a CRX smoking a $200k Lamborghini what excuse would that be he won? weight....Boost....?
#42
no im not saying that car sux. that car is badass. It just doesnt have 300hp you said you could get to 300hp without boost. I dont think thats gonna happen so I called bs and asked if you had proof that someone has done that. That hatch is fast but it doesnt have the 300 hp that you said the k20 could make N/A.
#44
regardless of whom was trying or not...
2006-07 Civic Si could easily get the 300HP as i mentioned N/A.
its not to far off man, Cams, Hondata, Camgears, Exhaust, CAI, etc..
then when the Kpro hits the market....BAM!
#45
Ill be supprised if you could make 300 hp NA. Again show me a NA k20 with 300 HP. The k20z1 isnt much different then the k20a2 in the RSX-S. I want to see an actual sheet like I showed you. I dont believe its as easy as you think. with cams, I/H/E, and kpro you may hit 250
#47
omgwtfbbq mod.
Rep Power: 287 Re: Sedan or Coupe
Also, just a little info for you. Read what people are posting for times with their bone stock k20's in various chassis. As you can see, none of the stock k20's are running any faster than 12.5's. Yeah, some of them break 12's but those are all modded. I guarantee you an EVO with 22psi would beat those times, hence why I stated that EVO was not trying in that video. It was obviously setup by hybrid racing to make it look fast. Anyways, read away.
http://www.honda-tech.com/zerothread?id=1468850
Now, on to your "300hp N/A" setup with a few simple bolt ons. Not so much. Do even just a little bit of research and youll realize that goal is rediculous. Impossible, definitely not, but not with some simple bolt ons like you mention. Read this thread that was posted by someone over at honda-tech:
http://www.honda-tech.com/zerothread...ostid=26433046
If you will notice, there are numerous replies on there stating it is nearly impossible for 300 whp from an NA k20.
Just do a LITTLE research and youll realize what your saying is rediculous.
you want 600+ hp from an all motor k? i have yet to see a k24/k20 hybrid make much over 300whp all motor so to double that would be quite a feat. (damn near impossible if you ask me)
good luck with your build, thats some very serious cash and time.
for 300whp/270tq I'd say $15,000-20,000 not including the car w/suspension/brakes etc....
#48
hey thats cool by me....wanna know why?
cuz i aint even got a k20....lmfao!
i dont know why these guy figured i had a k20 when its the DX trim on my car?
but i do feel that the K20 can come very close to that 300HP goal.
CAI = 8HP
Cam = 30HP approx
Hondata = 25HP
Exhaust system, lightweight flywheel, Kpro, or whatever else.....
100 HP gain is not impossible N/A wise on any car really?
.02
CAI = 8HP
Cam = 30HP approx
Hondata = 25HP
.02
#49
You where also saying that you had ~200hp which is what the k20 makes stock. The R18 makes ~140.... Your DEFINATLY NOT going to make 300hp on an NA engine like the R18
Those mods will only help that much if you other mods to back them up. Prove me wrong or give up! I would be willing to bet you wont get kpro either since the R18 is totally different the the K or D series engines.
#52
right now it is confidential info i cannot release, so i cannot even state the manufacturer, but as ive mentioned it is a Full build kit of course, as stock internals would not make it. The problem right now they are having is because of the shortage of room (engine is reversed of the K20, Exhaust on the R18A1 is up front where the K20 is in the rear....) is making something like a Ti bracket for the s/c itself.
i should mention....cuz i stated exhuast...haha!
is the S/C would be up against the side of the firewall VIA intake man
#53
why would the bracket material matter....... Its seriously starting to sound like ricer talk lol
#54
nope...its cuz it needs a stronger bracket then simply using steel, its in a real tight/bad spot where it needs to be at.
but thats ok man, you have the right to voice your opinion!
#57
Better figure out how to sleeve that block before boost. The Iron portion of the stock sleeves is much more thin then even the d17
http://www.hondatuningmagazine.com/t...ine/index.html
And 500hp on a k20 is much easier then 400 will be on the r18
#58
yo....nobody said it was gonna be easy bruh'
who knows maybe when its final release date arrives will actually be like
300HP or so....
im stoked eitherway man.
300HP or so....
#60
The pistons in these pics look like castings to me....
"Here's one that we've NEVER seen before: note the shape of the sleeves. There is a one-piece, ovalized, aluminum sleeve built into the block with ductile iron cylindrical sleeves pressed inside of it. Looks like boost might be a challenge with this block." -HT
