8th Gen 2006 - 2011.
Install headunit
Old 10-07-2007
JDrama1's Avatar
JDrama1 is an unknown quantity at this point
Install headunit
Lookin to install an headunit on the 07 civic lx...wondering if there was anyone that has the instructions on how to....I know i gotta buy an install kit....but i dont wanna break the darn thing......I had a 2000 Civic damn was that easy.......but yea help anyone?????
JDrama1 is offline
Old 10-07-2007
Hyperion's Avatar
Hyperion is an unknown quantity at this point
Re: Install headunit
This should give ya a general idea. http://http://www.handa-accessories....ivic-radio.pdf
Hyperion is offline
Old 10-07-2007
Hyperion's Avatar
humm link wont work try the handa website they have the instuctions there.
Hyperion is offline
Old 10-08-2007
JDrama1's Avatar
Thanks.......ill Check That Out
JDrama1 is offline
Old 10-08-2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
if you still need help, i think the plastic on the front of the dash pops out somehow, then screws are accessable to remove the deck, but my stereo shop guy told me it was a bit of a pain to do it?
you should post a DIY if you do it man!
then Civicforums would have an article on this topic.
FGCOUPE is offline
Old 10-08-2007
JDrama1's Avatar
No Doubt I Def Will Once I Take A Plunge Into It.....i Heard U Actually Needed To Disassemble The Dash.......im Not Looking Forward To That If Thats The Case Ill Let U Know>
JDrama1 is offline
Old 10-08-2007
arbittan's Avatar
arbittan will become famous soon enough
You will spend about 3 hours behind your new install. Very involved
arbittan is offline
Old 10-08-2007
soulrev's Avatar
Location: Fort Polk, Louisiana, 4/10 Mountain Division, 94th Brigade Support Battalion
soulrev is an unknown quantity at this point
That's a negative. Unless you have no idea what you're doing.
It's pretty easy. I just did this with my 07 civic a few weeks ago. First you need to remove the little side panel between the door and the dashboard on the driver's side. It should just pop out. Then you will need to remove the lower dash panel beneath the steering wheel. There will be a couple of screws involved there. No big deal. Then, you need to remove the upper dash panel above the steering wheel. If I remember correctly it just pops out. Disconnect the wires from the mirror switches. Then, in the little cubby hole underneath the HVAC controls, there's a little panel that will pop out with the help of a small flat blade screw driver. Now, you have to feel around up inside. There will be two bolts securing the entire dash-radio unit to the car. I think there were size 8 or 10mm. They're a pain in the **** to remove, too, so be patient. Once you remove those two bolts the dash-radio unit will pop out. Be careful to disconnect wires from the HVAC controls, the hazard light switch, and etc. before you just rip the thing out of there. You will also need a power antenna adapter, and a wiring harness adapter to hook up an aftermarket head unit. If you follow those instructions you should be able to install the head unit in about an hour, depending on your knowledge of cars and how good you are at splicing and soldering wires. Remember when you hook up the aftermarket harness you need to solder the wires and preferrably use heat-shrink tubing. Wire nuts are the wrong answer on cars.
Any further questions?
soulrev is offline
Old 10-09-2007
JDrama1's Avatar
Thanks for the install tips....should be pretty simple one civic to another im pretty knowledable in the civic department ha ha....but thanks....ill keep ya posted
JDrama1 is offline
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
mrwhos
08-11-2015 02:03 AM
17
07-23-2015 11:48 PM
EM_WON
07-22-2015 06:49 PM
Quick Reply: Install headunit
