8th Gen 2006 - 2011.
Resetting the Check engine light !?
Old 08-07-2007
TheM3Guy's Avatar
TheM3Guy is an unknown quantity at this point
Hello,
I have a 2007 Civic DX-G and recently after playing with it I forgot to hook up all the cables before trying to start the engine and now the check engine light stays on all the time ( all cables are hooked up now ). so I was wondering if there is a way to reset the light myself. I will hate to have to take it to the dealer for something like that as it will kill a lot of my time, which I don't have enough of as it is.
I read about a fuse you can pull out for a while which resets the light but I guess that is valid only for the older ones as it didn't work for me.
Thanks in advance !
TheM3Guy is offline
Old 08-07-2007
Alpha 5's Avatar
Re: Resetting the Check engine light !?
Ask the search button that very question. You are sure to find the answer. It is like magic.
Alpha 5 is offline
Old 08-07-2007
TheM3Guy's Avatar
I already did and all I found was about older models. None of the methods worked for me that is why I am posting.
But thanks for the suggestion anyway, I am sure it is a very helpful one for many people !
TheM3Guy is offline
Old 08-21-2007
TheM3Guy's Avatar
OK just an update on the CEL issue:
Few days later the light went off all byitself. So the system clears the fault code automatically once the problem is fixed
TheM3Guy is offline
Old 08-21-2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
depends on the problem.. sometimes it wont always fix itself.. even if you fix the problem sometimes it will stay on meaning it requires special attention
xproductionz is offline
Old 08-21-2007
yeah a code reader is great, otherwise gotta pull the battery or find and remove FI ECU fuse if you have that. newer civics do.
gearbox is offline
Old 08-26-2007
An elephant.... with stamps for hands.
thatsmrgimp2u's Avatar
thatsmrgimp2u is an unknown quantity at this point
Take off the negative wire on yer battery, turn on the lights and pump your brakes. Put it back on, start the car, and it should be gone (as long as the problem is fixed).
thatsmrgimp2u is offline
Old 08-26-2007
pumpin brakes has nothin to do wit it
Old 08-26-2007
Thats only to drain whatever charge your car has stored anywhere, its that "little extra" if you will. Prolly not necessary but if your in your car to turn your lights on why not pump the brake once or twice?
Old 08-26-2009
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
I tired the remove negative wire method and it work for now no need to pump the breaks any remaining power goes away quickly mines did!! will follow up and see how long it lasts........oops forgot to tell you guys that i never found out what caused the CEL to come on inthe first place.
SlimmKidd is offline
Xuhme
21
08-07-2023 03:40 PM
hernandexz
10-28-2021 10:52 PM
jetcare101
05-08-2015 01:33 PM
dooner24
04-14-2015 07:51 PM
bahena08
04-11-2015 05:09 PM
Quick Reply: Resetting the Check engine light !?
