Disabling daytime running lights?
#31
Re: Disabling daytime running lights?
I really don't mind the DRL as I am a safe driver...(see my post on my minor fender bender for ironic posting :P ) But all in all I still use my turn signal and keep my DRL's on, they really don't bother me.
#32
can you mod by hooking it up to a switch?is there a way to bypass the ebrake and the head light switch? the drl is activated by releasing the ebrake and is de-activated by turning on the headlights..
i want them both on at the same time., but have an option to turn drl off .. anybody have any ideas how this can be done?
#33
Rep Power: 787 Re: Disabling daytime running lights?
look for the DRL control box under the panel near the hood release. then its just a matter of testing connector wires to see which is the hot wire you need to put a switch on. i doubt you will be able to make them "stand-alone" when you can turn them on anytime you want, since they are so deeply integrated with the stock headlight wiring. but you can at least have a way to turn them off anytime.
#34
I just purchased a new 2009 Civic, am picking it up tomorrow, and I intend to disable the DRL before I even leave the lot since my lying dealer claims it can't be done. He found me the exact car I asked for, down to the last detail. The only thing I don't like is the DRL he claims can't be taken out or disabled. I hate DRL with a passion.
DRL are not a safety feature, they are the opposite of one. First, they encourage people to flat out ignore their headlight controls. This is fine as long as everything continues to work perfectly. If the photocell malfunctions, they'll never know, because their lights are still on, but they're now driving at night with no taillights. That's a safety hazard. If they then get into, oh, say, a rental or spouse's car that doesn't have DRL, they end up driving around with NO LIGHTS AT ALL until its pitch black and they suddenly realize they can't see for some reason. That's a bigger safety hazard. The only time they become a safety feature is when a driver gets used to having them.
Second, they waste gas. Minimal, maybe, but if I can save a gallon a year its worth it.
Third, they waste lifetime hours on the bulbs. Even if they don't blow, headlights dim over their lifetime. If you run them constantly, they dim faster. At NIGHT, when I NEED them, I like bright lights. And I don't like replacing them regularly to keep them bright.
Fourth, they just flat out annoy the hell out of me when I see other people driving with them. High noon under a clear sky, and you have your lights on. Are you retarded? Its two in the afternoon and I'm sending my son out to work in the garden. Here, Junior, don't forget to take a flashlight with you. We tell our kids to turn off the lights when they leave a room, leave the house, go to bed, or whatever to save on the electric bill. Turn them off when you don't need them. Why doesn't the same rule apply in the car? If you can't see me at midday under the bright sun, you probably don't need to be driving at all anymore. If I realize you can't see me under the midday sun, I will call the local highway patrol to bring your blind butt in to be retested. If, however, it is dim, dark, dusky, foggy, rainy, extremely overcast, or for any other reason either I need to see better or I believe others might need a little help seeing me as well as possible, I still possess the common sense, courtesy, and physical ability to move my left hand three inches to the left and two inches forward and turn a small switch 45 degrees in a counterclockwise fashion. This motion does not require me to take my eyes off the road, nor does it in any way distract me from driving. That's what cell phones are for, which is another topic altogether.
Sorry for the rant. Think I made my point, though.
#35
Canadian, Eh!
Rep Power: 252 Re: Disabling daytime running lights?
You may know a lot about cars or you may know nothing but your post clearly makes it sound like you know nothing about how the world works and have complete ignorance to how other drivers operate at times.
#36
i like my turn signal drl, in fact i spent money and purchased the system myself cause my car did not come with one. they are very handy on cloudy/rainy/low visibility days when i dont feel like wasting all my park lights and headlights. when its sunny, i just turn them off. no sense in wasting my expensive turn signal bulbs either. but i do agree that white hi beam drl is pretty crappy looking and doesnt really increase safety as much as amber light (usually from turn signals). the signal drl wastes less power than hi beam drl at 1/2 power. and youre right, when you run the hi beam bulbs at low power, they start to turn brown since there is no halogen cycle going on. but at least you can run them at full power by using the hi beam and eventually they will turn clear again. running halogens at low power, however, will not reduce their lifespan. in fact, they prolly would last more than twice their normal life. i suggest you put a switch on yours and just use it when you feel like. alot of 06+ civic guys also change the hi beam bulb with a yellow one to add uniqueness. just keep in mind they do start to get annoyingly bright when it gets too dark outside. if its near dark but still light enough to see, i will usually just switch the park lights on instead. heres a pic of my drls. very noticable and bright, ive had cars actually sit and wait for me to pass instead of turning in front of me so they could check out my car.
#38
Rep Power: 0 Re: Disabling daytime running lights?
My DRL light buzzes when I put down my handbrake. If I take out the fuse... will this be fixed?
Which Fuse? My fuse box is under the hood on the passenger side.
#40
I must chime in here.... For the most part I agree that the DRLs improve visibility from the front! That doesn't mean that I like them though.
first reason: It does nothing to the tail lights. Lots of the idiots around here think that their DRLs are an acceptable substitute for headlights in the rain. Have you ever heard the expression "Louisiana rain"? (picture really heavy, with almost 0 visibility). DRLs do nothing for improving visibility from the rear.... It's lots of fun coming up on an idiot driving 25mph in a 50 zone because of a little rain, and having to slam on the brakes because you can't see him until you're almost introducing yourself!
second reason: I work weird and crazy hours, frequently coming home in the middle of the night. My son's bedroom window faces my driveway. As a result of this I turn off my headlights as I'm entering the driveway, preventing a "spot light effect" on his window. Although the DRLs are not as bright, they will still cause this spot light effect
That being said, I'll probably keep my DRLs operating, as I know when my headlights need to be turned on, and do so. When I come home at in the middle of the night I will typically back the car in to the drivway (the reverse lights are not anywhere near as bright as the DRLs on my car)
JMHO
Exco
JMHO
Exco
#41
i completely agree, which is why i am currently bypassing the drl safety to allow them to run in both parking and headlight mode. unless its only cloudy, headlights come on for me in any other bad weather. and the drls add to the visibility while still functioning as turn signals. my drl has its own master switch to easily switch off and on as i please. but using the turn signal bulb, its not nearly as annoying as some hi beam drls.
#42
Received 1,440 Likes
Rep Power: 338 Re: Disabling daytime running lights?
I am temporarily living in Canada and will need to install DRL.
However, back in TN, i would always turn my parking lights on as soon as i turn the engine on (habit).
For the average driver, they don't care, so the DRL is a must, sorry to say...
I will turn my parking lights as always, will disable the DRL as sson as i get passed the inspection anyway. It does not turn the rear lights on.
For the average driver, use the the DRL. For concerned drivers, turn it off! The best ABS i know is human, except for ice.
that's all.
that's all.
#43
DRL doesn't bother me. It's a safety feature for me because I know people on the road can see my car due to the DRLs being on. People have pulled out in front of my mom many times because her honda accord is a similar color as the road and it has no DRLs. Although I definitely do not let my guard down just because DRLs are on.
One thing that does bother me though with my 2009 Honda Civic is the DRLs do not turn off when I put my car in park and apply the parking brake. When I get into my car and start the engine, as soon as I release the parking brake and put the car into drive the DRLs turn on. But if I put the car back into park and apply the parking brake they continue to stay on unless I turn off the engine.
I was wondering if the other 2009 civics do the same thing or is something defective in mine?
One more thing, when you guys took a fuse out of your car just to disable the DRLs did you turn your parking lights on and look at the front of your car to see if they turn on?
#44
I just bought my civic in december, and wouldnt dream of disabling the DRL.
Why?
I dont see them (the DRL on my car), but the other drivers do, which helps them to see me coming. Why is this even an issue when you cant even see them while youre driving your own car?
The other driver - So you see their DRL on the highway, heading toward you at highway speed, imagine if they were passing a slower vehicle, their DRL helps you see it happening at a distance, because the DRL themselves are alerting you to their presence on the roadway (if you only see one of their DRL, they are staying in their lane, if you see both, they are probably passing another car and are in your lane).
Why do people think this is such a bad thing?
And dont give me the "their not bright enuff" or something because I have averted many an accident thanks to the DRL on the other guys car, even tho he/she was being an *** and being in way too much of a hurry. I drive 37 miles to AND from work everyday thru 3 counties so I see this type of thing 6 days a week.
And im thankful for DRL!
Why?
#45
if u dont want ure DRl's on when u first start up your car then dont touch the brake when u start the car. i ahve the 5spd 06 ex and i jsut set the parking break and start the car and my day time running lights stay off until i hit the brakes at some point. My wife's 2010 civic turns on when u hit the break to put it from park to reverse or drive... so it just depends on ure car but i pulled my fuse and it hasn't caused any problem. i love my civic other than some minor issues i am having cause my intake is to big for my car.
#46
Who would have thought it'd be as easy as removing a fuse? Just removed #37 from my new 2011 Civic and glad to be rid of the DRLs!
FYI - to all the people that wonder why you'd want to disable DRLs, I disabled mine for safety. The DRLs are too bright, and being a city dweller, it's easy to forget to turn on your headlights at dusk. I even forget to turn on my headlights at night sometimes, since the DLRs are so bright.
#47
Disabling the DRLs was the first thing I did. It was done the day I bought it.
Low bean DRLs don't bother me, high beam DRLs (like the Civic) annoy me.
http://lightsout.org/
Pulling the DRL fuse cause absolutely no other problems with the car.
#48
drls are just a waste of resources (gas), unless you have leds like the audi. if you cant see cars in bright sun, you shouldnt be driving. and if its cloudy, turn your lo beams on. its amazing how many people cannot grasp such a simple concept lol. luckily with civics its just a couple fuses.
#49
I have noticed that when I am driving a car with Daytime Running Lights, the car in front of me will tend to slow up a bit.
I have been told that drivers do this because they find the DRL's annoying and are trying to encourage the car with DRLs to "go around".
From lightsout.org
"The National Highway Traffic Safety Administration has recently released a technical report finds DRLs are of practically no use, and further admits that DRLs have negative safety consequences."
From lightsout.org
#50
i was going crazy when a motorcycle got behind me today with non-stop flashing hi beams! the lo beams were also on but flashing hi beams? i was getting so distracted and annoyed and my eye was constantly looking back in the rear mirror. i could see his lights reflecting off speed limit signs in full sun! i am all for those guys making themselves more visible, but this is way too far and could easily cause accidents. get an hid kit, some driving lights, amber drls whatever so long as they are not flashing im okay with glare. i seriously felt like running him off the road for being so annoying.
i will admit that amber turn signal drls are not annoying and do make some cars look "cool" but as far as visibility, i can still see a car just fine without any lights so long as its not nighttime.
#51
or the option of fog lights being used instead
#52
SRCivic03
Ready to Pull my DRL fuse I have either the noise under my dash or the "DRL" warning light on my dash all the time until I turn the normal night lights on.
I was just curious if that will solve the issue with my high beams not working if I pull the DRL fuse.
#53
I disabled my DRLs, if you cant see a bright red car during the day then you should not be driving. I just did not like the way that they looked and I see no safety benefit. Ive driven vehicles with and without DRLs and I have not noticed a difference. Actually the truck I used to drive without DRLs, ha ha, no one was pulling out in front of that...
#54
Hi there,
You may need to check ur user mannual and in fuse section find out which fuse number is belong to DRL then remove it and that's it.
I've got a civic 2014 and the fuse number is 21 (7.5 amp)
Cheers
Cheers
#55
Below are the steps to turn off the daytime running lights while keeping the vehicle running.
Works on my Honda civic coupe.
- Turn off the vehicle.
- Engage the parking brake
- Turn the Vehicle back on
mikecivexxx
01-19-2007 08:27 AM
