8th Gen 2006 - 2011.
Cabin Filter in 2006 - where ?
Old 05-15-2006
KRM
KRM's Avatar
KRM is an unknown quantity at this point
Question Cabin Filter in 2006 - where ?
Does anyone know where to find access to the cabin filter in the 2006?
In the 2005 it was in the glove box, but I don't see anything in the 2006
glove box.
Thanks,
KRM is offline
Old 05-15-2006
imported_Mikey's Avatar
imported_Mikey is an unknown quantity at this point
There was another thread here about that.. I was sure they said it was in the glove box.
Can anyone confirm this??
imported_Mikey is offline
Old 05-16-2006
KRM
KRM's Avatar
That was a post for the 2005 model.
KRM is offline
Old 05-16-2006
pico's Avatar
pico is an unknown quantity at this point
Check the owner's manual. Im pretty sure its in the same spot. You drop your glove box past the stops and it should be staring at you. Ill check mine tomorrow.
Yep. Right behind the glove box. Even easier than the 7th gens.
pico is offline
Old 05-22-2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
so how come he couldnt find it in the glove box?
Is it tougher to see there now?
imported_Tricky is offline
Old 07-22-2006
chuckseider's Avatar
chuckseider is an unknown quantity at this point
Cabin air filter
The owners manual tells you to take your car to your dealer to have the filter changed. It is behind the glove box and to change it open the glove box, squeeze the sides of the glovebox inward and it will swing out of the way. Press the 2 tabs on the filter towards each other and pull the filter out. It could not be easier to change.
chuckseider is offline
Old 07-26-2006
KRM
KRM's Avatar
Thanks all,
It found it OK.I was a little afraid of breaking the plastic when bending the sides, but it worked fine.
KRM is offline
rayaan_wasty
09-14-2015 02:00 PM
John2009
09-10-2015 09:53 PM
Christian123456
09-09-2015 05:26 PM
NaturalSelectio
09-06-2015 06:59 PM
johnsoda
09-06-2015 04:00 AM
Quick Reply: Cabin Filter in 2006 - where ?
