8th Gen 2006 - 2011.
maintainance questions
Old 11-25-2014
EarleD's Avatar
EarleD is an unknown quantity at this point
Hi everyone...
I just scheduled my 2011 lx for a full synthetic oil change and my 3rd trans service in last 3 oil changes. I figure I have now replaced all trans fluid with new Honda fluid. Going to continue with a trans service every 4th oil change. Love my civic, and since I drive about 750 miles weekly for work it a little gem. I bought the car 1 year ago with 25000 miles.
I go to Honda for all maintenance, as I have no skills working on cars. Was thinking about replacing either antifreeze or brake fluid. Both are original I believe. Which one should I do first? Car has 58000 miles.
Power steering fluid seem very easy to change myself, I might attempt this. get a turkey baster and 3 bottle of Honda brake fluid. Just suck it out of the ps "container" and refill with new. Start car and turn steering whell end to end several times. Repeat process several times> ????
Thanks a lot and happy Holidays
EarleD is offline
Old 11-25-2014
Re: maintainance questions
Brake fluid is recommended every 3 years.
Coolant isn't recommended until 10 years or 100,000 miles (MM item #5). Read the hood label, the coolant info is right on it.
PS fluid, we don't have much of a problem with the PS.....and if you do it, make sure to get the correct HONDA fluid. It is NOT ATF.
Someone posted a DIY on it the other day: https://www.civicforums.com/forums/1...ing-flush.html
ezone is offline
Old 11-25-2014
Nelsonsdad's Avatar
Nelsonsdad is an unknown quantity at this point
Genuine Honda automatic trans fluid is not as good as Valvoline. I did two changes at 30 and 35K to change 3/4's of it, and the transmission is twice as good as new. Do not was money on Honda fluid. Easy way to change brake fluid is to use a turkey baster to evacuate the master cylinder tank about every other year, and refill. Don't disturb the rest of the system. The fluid will change itself over time. Been doing this with many cars for 20 years with no problem.
Nelsonsdad is offline
Old 11-25-2014
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Any actual data to back up those claims?
Opinions /= facts.
Just because a transmission feels smoother doesn't mean it's wearing less.
jordan1794 is offline
Old 11-30-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Originally Posted by EarleD
Hi everyone...
Yup... exactly what I would do on any used car I purchased.
changing fluids and filters on your Honda is real easy there are
youtube videos for the do-it-your-selfer that you can watch.
You missed changing the spark plugs, air filter, and lastly cabin
air filter. again real easy to do yourself.
brags is offline
Old 11-30-2014
^Spark plugs are 100,000 mile items in these.
Air and cabin filters, the MM will pop the reminder for them around every 25k (with the nearest oil change reminder), give or take a little.
If you drive in super dusty/dirty conditions or anything, you may need to change the filters more frequently. The Maintenance Minder cannot actually monitor anything going on in the car.
ezone is offline
muniorbust
33
08-31-2015 08:59 PM
martinsmartin
08-15-2015 07:34 PM
spyder13
07-31-2015 06:31 PM
Green02civic
07-27-2015 10:48 PM
sam31444
ECU Fried
07-20-2015 08:31 AM
Quick Reply: maintainance questions
