8th Gen 2006 - 2011.
Cold Air vs. Short Ram Intake
Old 02-08-2015
  #31
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Re: Cold Air vs. Short Ram Intake
well many professional teck"s I talk too like K&N filters and intake kits
if you go online to the K&N site it will tell you exactly what your going to
expect as far as H.P. gains from one of these K&N hook up kits.
brags is offline
Old 03-16-2015
  #32
brags's Avatar
do cold air intakes really make any kind of difference.? this one didn't
mind you they don't mention the brand and it doesent look like a K&N neither
brags is offline
Old 01-12-2018
  #33
Rob Vee's Avatar
Rob Vee is an unknown quantity at this point
Go with injen
Rob Vee is offline
Old 01-29-2018
  #34
92Hatch95's Avatar
92Hatch95 is an unknown quantity at this point
Injen cold air intakes have allegedly been tuned to the car.
A true cold air intake tends to have better results than a short ram intake. However, gains aren't fully realized until the car is tuned with the modifications. Prior to that it's running in stock format accept in light load/pedal positions and that's not where people play when they have an intake.
As for rain and true cold air intakes, there is a water sock you put over the filter to keep from sucking water. You just need to avoid slamming into lakes on the side the CAI is.
I have an 07 Si with full Skunk2 Megapower 70mm exhaust and the Injen Cold Ait Intake. Car has been street tuned by E-tunez. No other engine mods, stock engine otherwise.
Stock the car is supposed to have 197 bhp and 139 ft-lbs torque at the crank.
After the tune, I had it dyno'd. The car makes 203 hp at the wheels and 148 ft-lbs of torque at the wheels.
Cold Air Intake and Exhaust does give significant gains if the car is tuned with the mods.
92Hatch95 is offline
Old 09-25-2019
  #35
Hollow_dash's Avatar
Hollow_dash is an unknown quantity at this point
Cold air all the way
Hollow_dash is offline
98dx
02-25-2010 07:15 PM
familyguycivic
08-15-2009 01:58 PM
djrabbi
01-31-2006 06:56 PM
nooboob
Bolt-on Engine Performance
16
06-13-2005 10:21 AM
salokod
04-19-2003 07:41 PM
Quick Reply: Cold Air vs. Short Ram Intake
