Go Back   Honda Civic Forum > Honda Civics by Generation > 8th & 9th Gen
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
8th & 9th Gen In the years from 2006 to 2011 Honda released it's 8th Generation Civic. Chassis codes: FD2, FA1, FG1, FG2, FA5, FK, FN
LinkBack Thread Tools Search this Thread
Old 08-09-2010   #1 (permalink)
kgelliott is an unknown quantity at this point
Reset after OIL Change
Somehow my wife doesn't have an owner's manual for her 2009 Civic we bought last year. Recently, we had its oil changed at a non-Honda dealership, and the OIL life dash display was not reset. Hence, we have an annoying yellow wrench that appears every start up along with a negative number of miles from when service was required...even though the oil and filter have been changed.
What are the easy to follow steps to reset this after an oil change?
Thank you VERY much for your help!!
kgelliott is offline   Reply With Quote
Old 08-09-2010   #2 (permalink)
Low and slow!
02civicsi02's Avatar
Points: 4,757, Level: 44
Points: 4,757, Level: 44 Points: 4,757, Level: 44 Points: 4,757, Level: 44
Level up: 4%, 193 Points needed
Level up: 4% Level up: 4% Level up: 4%
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Re: Reset after OIL Change
You can probably do the trip miles button trick. Get in the car and put the key in the ignition and hold the trip miles reset button. Hold it for bout 5 seconds then turn the key to on while still holding the button. Hold it for bout 10 seconds after you turn the key to on and it should go off if not then an another easy way is to reset your ecu. The ecu fuse is in your engine bay fuse box. Locate it and remove it and plug it back in and it should be off. Sometimes on some cars there is a reset button under the drivers dash. Its on the right side of the steering wheel under the dash like where the fuse box is you can just feel round for it to see if you have it.
__________________
99 mr em1- R.I.P
02 tw ep3 - DD (slammed)
97 pw db7 - Sold
99 fbp em1 - DD (b18c type r swap)
02civicsi02 is offline   Reply With Quote
Old 08-09-2010   #3 (permalink)
25 Years Japanese Autos
CraigW's Avatar
Points: 20,742, Level: 90
Points: 20,742, Level: 90 Points: 20,742, Level: 90 Points: 20,742, Level: 90
Level up: 79%, 108 Points needed
Level up: 79% Level up: 79% Level up: 79%
Activity: 90.0%
Activity: 90.0% Activity: 90.0% Activity: 90.0%
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
With the key at II, press SEL/RESET until the oil life is displayed, then press and hold SEL/RESET until it goes to 100%.
CraigW is offline   Reply With Quote
Old 08-29-2010   #4 (permalink)
bobby digital's Avatar
bobby digital is an unknown quantity at this point
they tried to tell me about that at the dealership and i was so ready to leave i wasnt paying attention... thanks for the reminder
bobby digital is offline   Reply With Quote
Old 08-29-2010
CivicForums
Honda Civic
Paid Advertisement
Tags
02 , 07 , 2010 , 8th , button , change , civic , ecu , fuse , gen , honda , life , oil , reset , si
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Wiper Blade Replacement - how?
Timing belt or timing chain...
Question about Honda Civic Auxiliary Input
Sun Visor split open?
2006 Civic Auxiliary Jack Installation.
Best Color for the 2006 Civic?
2007 Civic SI 3rd gear news
wow type R and mugen RR body kit
Civic Car-Care
Seat Belt Chime Gone! Seatbelt Chime Gone
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
