Rear Control arms, rear tire wear early models the early models had an issue with the rear control arms (upper) and have a tendency of rapid rear tire wear
06 Civic Hybrid Rear Suspension Defect
Old 07-13-2010
dfnail's Avatar
dfnail is an unknown quantity at this point
I bought a used 06 Hybrid a couple of years ago and did not discover that it had a rear suspension design defect until recently. Because of mileage Honda will not correct it even though they did for owners who complained within the warranty period. The defect involves the rear upper control arm that causes too much negative camber that results in abnormal wear on the inside of the rear tires. This was corrected in the 08 models. Does anyone know of an inexpensive way to correct this problem?
Old 07-13-2010
Re: 06 Civic Hybrid Rear Suspension Defect
aftermarket camber kit and an alignment once its installed should work. or just call corporate honda and ask for a goodwill repair. they might pay for some or all of the bill.
Old 08-13-2010
dfnail's Avatar
Honda finally took care of the problem and covered everything but the alignment cost. It took filing a complaint through the BBB and others before they agreed to cover it.
tylerginevan
04-27-2015 12:29 PM
inarschenk
South
04-18-2015 04:29 PM
dooner24
04-14-2015 07:51 PM
CapYoda
11-11-2001 05:17 PM
Quick Reply: 06 Civic Hybrid Rear Suspension Defect
