What type of gas do you use?
1 Post
Rep Power: 0 Cheapest that I can find. I actually got my last tankful at $1.99 per gl. I was passing the station at 6:30 in the morning and the attendant was changing the board, when i saw the "1", I made a u-turn and filled up. I bragged and showed everyone at work my receipt as proof, but by the time we all got off the price was back up to $2.16 gl, which is still pretty good, concidering...
The manual says 87 or higher... unless you have an Si... says 92 or better for them.
92-93 will not give you more performance unless you are running high compression than what is stock.
87 octane only. With this car you wont get better milage or performance with 93. Only pay @ 20 cents more per gallon.
I usually buy Chevron/Texaco because thats the credit card I have. I always fear off brand station gas quality. Truth is, they say most gas is the same when it gets to the station. Then the name brand stations pour in whatever additive their corporate headquarters use (ie Chevron with Techron).
Rep Power: 0 probably right you are, i use Quick Trip because it is a huge chain, and i wanna stay consitent with the gas i use and QT's are everywhere around here. plus with all of the business they get, if they **** up, CLASS ACTION!!!
Rep Power: 0 They Say To Use Premium In Vehicle With Hi Compression Such As The Si, Usually With Compression Ratios Over 9.5 Or 10 To 1, So Keep In Mind The Base Model Civics Also Have Over A 10.1 To 1 Compression Ratio, Therefore I Use Premium In My 06 Lx
Rep Power: 0 Blue (89?) from amoco. have bought gas there for 10 years, never had problems with it.
edit: sorry, I forget these forums are not generation specific. I have an 05 and this thread is for 8th gens.
Rep Power: 0 I would advise against using Premium. If the car is designed to run on 87 octane and you put 93 octane in you will have unspent fuel build up in your engine.
You may be able to get away with 89 octane since this is a higher compression motor and with some spirited driving you should be able to, 'blow the carbon out', but I wouldn't go as high as 93.
Touge
Ottawa
07-18-2015 05:39 PM
Touge
07-18-2015 05:35 PM
cgavin1
07-07-2015 07:10 AM
