Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
FJCruiserSI
New Member
FJCruiserSI is an unknown quantity at this point
Buying 2000 LX 66000 Miles: What Shoud Be Inspected?
Before handing over the cash I want to check all areas of concern. The car was in Miami for several years. The belts show signs of beginning to crack but not badly. CV Boots are in good shape. Only thing "significant" is major oxidation of the aluminum engine due to salt air but naturally this affects nothing. No Oil Leaks.
Are Belts Tough to Replace on This Car?
Anything I Should Inspect Carefully?
FJCruiserSI is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Buying 2000 LX 66000 Miles: What Shoud Be Inspected?
usually belts should be replaced every 90k miles. accessory belts are not too difficult, its the timing belt that takes some work. just do an overall check and make sure there are no leaks and the car drives smoothly when warmed up.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 1 Week Ago   #3 (permalink)
FJCruiserSI
New Member
Bought the car but here is the killer: Car Looks Almost Pristine Considering it is a 2000. Interior almost flawless, no wear, etc. The analog odometer is NOT perfectly lined up however. CV Boots are original and not torn, basically everything looks and runs perfect. Car Fax is clear and checks out.
I Wonder If It Was A Rollback And How Could It Be When a 10 Year Old Car Looks New? The first 2 digits the 60K and the 6K are perfect, the other 3 are slightly off.
Any Ideas?
Old 1 Week Ago   #4 (permalink)
gearbox
Super Moderator
ive seen that happen alot on the older odometers. i dont think you have to worry. some people just dont drive much. our 92 accord only has 90k miles and its in pretty good shape too.
__________________
www.lubecontrol.com
Member 1025782
Tags
03 , accessory , belts , change , civic , honda , lx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
