Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
ngm
New Member
ngm is an unknown quantity at this point
Steering at H/way speeds
During a recent roadtrip, My Civic suddenly darted to the left. It only lasted for a split second, but then began to do it a couple times more @ 75mph. Also the steering wheel acts almost like the power steering is grabbing, making the wheel twitch while I'm going in a straight line. P/S fluid was a bit low so I filled it up. The car usually rides fine at hway speed no odd vibrations for a car with 283K. I looked underneath and nothing looks messed up with the suspension and the wheel weights are still in place. Any ideas what could be going on?.
Peace Out!
ngm is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Steering at H/way speeds
probably suspension related. make sure your stuff is tight like tie rods and control arms, and have the alignment checked. something seems like its loose and could cause a big problem later.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
ngm
New Member
Hi i looked under the car today and noticed the drivers side CV boot is split right around. Could that be contributing to the problem?.. I can see the guts of the CV joint, but there's no clicking when I turn...
thanks
Old 2 Weeks Ago   #4 (permalink)
ngm
New Member
thanks
Old 2 Weeks Ago   #5 (permalink)
gearbox
Super Moderator
get it fixed quickly, before the joint goes bad from no grease. i dont think that will cause any problem unless its bad already. then yes it could cause the car to pull one direction.
__________________
www.lubecontrol.com
Member 1025782
Old 13 Hours Ago   #6 (permalink)
ngm
New Member
As an fyi, when i did a detailed inspection underneath, ended up replacing the axle (torn CV boot) , steering rack boot (also torn), drivers side ball joint and both tie rods. So far so good. Taking it on a long road trip today - we'll see how that goes. Peace Out!
Tags
civic , honda , news
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
