Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #1 (permalink)
bucknut
New Member
bucknut is an unknown quantity at this point
2000 Honda Civic EX transmission issues
This problem started a few weeks ago. I have check the trans. fl levels and it was good. The fluid was not burnt up either. When I drive off from a dead stop the trans slips a bit b/f it catches. When I drop it down to the low gear the problem doesn't happen. It only happens when its in D4. What are some common parts that can fail to cause this? Will I need to get a whole new transmission? Any info would help out, guides, links, anything. To remove this ad, register today for free or log in if already registered!
bucknut is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
BOSHARK
New Member
BOSHARK is an unknown quantity at this point
Re: 2000 Honda Civic EX transmission issues
bucknut, I just started havin the same problem, it started last week as soon as the weather got cold. Best I can tell from reading other posts is that the o-rings in the tranny are getting old and brittle, and when the tranny warms up the o-rings soften up and the problem stops,(for now) Seems like the only temp. fix is to change the tranny fluid (witch i've never done) But soon the tranny will be F%$#ed. Let me know what you find out. thanks,BOSHARK
BOSHARK is offline   Reply With Quote
Tags
03 , 2000 , 2001 , 2002 , check , civic , costs , filter , fluid , honda , level , problem , slipping , slips , tranny , trans , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
