Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #1 (permalink)
sortsa77
New Member
sortsa77 is an unknown quantity at this point
Exhaust Manifold Glowing Red
We had the timing belt and water pump replaced about 2 weeks ago for routine mtce. The other night the car started running really rough, the engine light came on and when the hood was opened the exhaust manifold was red. Next morning you could see a very small crack in the ex manifold. I was told it was likely the cat clogging so I replaced it and the car ran fine on a 5- 10 mile trip. My son jumped in the car after it had been off for a couple of hours and in about 1/2 mile the same problem happened. I haven't looked at it to see if it cracked again, waiting for first light. Could it be a bad O2 sensor? showing
sortsa77
sortsa77 is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Exhaust Manifold Glowing Red
wont be a bad o2 sensor, could be clogged exhaust from the cat going bad, if the cat went bad.
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 4 Weeks Ago   #3 (permalink)
sortsa77
New Member
We just looked at it. No visible signs of a crack. Disconnected the upper O2 sensor and it runs fine, so far.
Old 4 Weeks Ago   #4 (permalink)
seoul4korea
Member
seoul4korea is an unknown quantity at this point
Quote:
He said that he replaced his cat and came back with the same problem. I was just saying as a side note his O2 sensors more then likely burned out after words as well. The only thing that I could think of is that the O2 sensor went bad which could have cause a lean condition (I know it's suppose to go in to Limp home mode and run 14.7 a/r ratio) Purphase a lean condition caused higher exhaste temps which turned the manifold red?? These are all just quick thinking so hopefully you figure it out.
seoul4korea is offline   Reply With Quote
Tags
1986 , accord , bad , cat , civic , coil , exhaust , glowing , glows , honda , ignition , limp , manifold , mode , oxygen , red , sensor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
