Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-15-2009   #1 (permalink)
5thGenvtec
New Member
5thGenvtec is an unknown quantity at this point
Power window demon
Hi Everyone, I am new here so please help me if you can. I have a 99 si (ex usa) and my problem is with the passenger side window. I have no response from the driver side control and the passenger side control only works to take the window down. I tried a new assembly and the same thing happened. Right now I am really lost here so please any help would be greatly appreciated. To remove this ad, register today for free or log in if already registered!
5thGenvtec is offline   Reply With Quote
Sponsored Links
Old 10-15-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Power window demon
What new assembly ??
Have you tried putting voltage direct to the disconnected leads of the motor to see if it will move then ??
CraigW is offline   Reply With Quote
Old 10-15-2009   #3 (permalink)
5thGenvtec
New Member
Okay, here is where I am. I applied power directly to disconnected leads and nothing happened, so I applied ground on one side and power on one and I got up and down movement dependind on which way the power/ground was applied. So might this be a problem with the harness itself? and if so, how hard is this to change if I can put my hands on one?
Old 10-15-2009   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Here are the schematics for the system. It may help to troubleshoot the problem. You should try to locate the free factory 96-00 Civic service manual on the web. It will have the procedure for checking the switches and wiring.
Old 10-15-2009   #5 (permalink)
5thGenvtec
New Member
Thanks so much. This is really helpful
Tags
2001 , 96 , accord , civic , controls , forum , honda , power , problem , schematic , side , troubleshoot , window , windows , working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
