Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-19-2009   #1 (permalink)
dinsuncity
New Member
dinsuncity is an unknown quantity at this point
driver wrench and heat to take off crankshaft nut?
i know this has been asked in various ways but i need to confirm something.
i need to get my crankshaft nut off and i read about the special tool. but I have a 500 lbs 90 psi 1/2 driver wrench with 150 psi compressor. it didnt work i tried 3 times. but im soaking it with wd 40 over night, then im gonna rinse it off in the morning and take my map gas torch to it. if i get it hot then try with the gun will it work? i read this i think a couple times but im not sure.
didnt i also read that 300 or 400 lbs would work? not for me man this thing is on tight.
dinsuncity is offline   Reply With Quote
Sponsored Links
Old 09-19-2009   #2 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: driver wrench and heat to take off crankshaft nut?
Try around 1100 foot pounds in some cases. Get the crank pulley tool, two 1/2" breaker bars and a big cheater pipe. Best way to do it without air tools.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 09-19-2009   #3 (permalink)
dinsuncity
New Member
ya nothing is working so far. i dont understand 2 bars and a pipe? keep in mind that the car is on jack stands. do u have a picture u can post of that setup?
Old 09-19-2009   #4 (permalink)
dinsuncity
New Member
i just ordered the part after reading some reports of 650 lbs guns not taking off the bolt. ic what u mean by 2 bar... sorta. put one on the part that i just ordered, and break the bolt with the other. but after reading the reviews of the tool, which got 5 stars all the way, noone mentioned a pipe. a pic would surely be nice
Old 09-19-2009   #5 (permalink)
dinsuncity
New Member
oooo!! is a cheater bar to extend the breaker bar?
Old 09-19-2009   #6 (permalink)
speedfoos
speedfoos's Avatar
Yep. Cheater bar. One breaker car goes on the pulley tool to hold it steady, the other breaker bar has the 19mm socket for the crank pulley bolt. The best way to do this is to use a jack stand to support the extensions that your using to make your 19mm socket reach the crank pulley bolt. This way all force goes towards loosening the crank pulley bolt and you have less up and down movement if the breaker bar/cheater bar/extension/19mm socket assembly is supported by a jackstand to pivot on. Check the Timing Belt DIY by reddawnman for what I'm talking about. It's a short video that shows this.
__________________
www.7thgenhonda.com
Old 09-20-2009   #7 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
ive used 1180 ft/lbs before and not had it come free, breaker bar and crank tool is the only right way
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Tags
2003 , 2004 , 92 , accord , bolt , civic , crank , crankshaft , honda , loosen , lx , nut , pulley , removal , wrench
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
