Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-19-2009   #1 (permalink)
dinsuncity
New Member
dinsuncity is an unknown quantity at this point
how to get into nuetral for T.D.C.
ok heres the story
im changing my timing belt and water pump. im using the chilton civic book for my 2002 honda civic ex. im going step by step. so far heres what i have off
-drive belts
-alternator
-power steering pump (cables still attached of coarse)
-motor mount (2x4 under oil pan with hyd jack)
-ignition coils
-head gasket
so now heres where im stuck.
I have to find TDC (top dead center) but I have to shift the car into nuetral! with the alterator out and everything off how do i get the darn car into nuetral? is there a manual way to do it?
hopefully theres an easy way!
thanks
dinsuncity is offline   Reply With Quote
Sponsored Links
Old 09-19-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: how to get into nuetral for T.D.C.
is it auto or manual? i know with autos, there is a lil hole with a cover on top on the shifter that you stick the key in and the shifter will move (gotta pry off the cover first). not sure with manual but im guessing you just press the clutch in and you can move the shifter.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-19-2009   #3 (permalink)
dinsuncity
New Member
ya! its auto should i give that a try
Old 09-19-2009   #4 (permalink)
dinsuncity
New Member
do i have to take the whole plastic consol shell off?
Old 09-19-2009   #5 (permalink)
dinsuncity
New Member
ohhh on the top of the shifter. ill go look ty
Old 09-19-2009   #6 (permalink)
gearbox
Super Moderator
its just a small plastic tab. use a screwdriver to carefully pop it off, then the key sticks straight down until you hear the mechanism click and you can move the shifter like normal.
__________________
www.lubecontrol.com
Member 1025782
Tags
1994 , 2000 , 2004 , 89 , 99 , center , civic , dead , dx , find , finding , honda , si , tdc , top
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
