Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-18-2009   #1 (permalink)
Springerrr
New Member
Springerrr's Avatar
Springerrr is an unknown quantity at this point
Tranny woes
Hello Gentlemen,
The automatic transmission in my ’97 Civic LX (1.6L v4) started slipping in low gear when it was hot. The first time this happened the check-engine light came on. I took it in and the scan showed:
* PO420 – exhaust convertor (yah, I know, yet another problem)
* PO700 – transmission fault in controller
* PO715 – Input speed sensor fault
Mitch thought the trans fluid looked ok and suggested we change out the tranny’s main pickup assembly and linear solenoid (a $500 job). This did nothing. Now he says it’s time to put in a used tranny ($800). The total for all this is $1,821.35.
Based on those codes, do you believe changing out the assembly and solenoid was the correct first step? Anything else we should look at before swapping out the tranny?
Thank you so much!!
Sandy
Springerrr is offline   Reply With Quote
Sponsored Links
Old 09-18-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Tranny woes
i wouldve changed the trans right away. usually thats the cheapest and easiest option. slipping gears means its toast inside and must be completely rebuilt or replaced.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Tags
01 , 2002 , assembly , change , civic , codes , honda , linear , po700 , po715 , solenoid , trans
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
