Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-10-2009   #1 (permalink)
cow_jive
New Member
cow_jive is an unknown quantity at this point
2001 honda civic, trying to diagnos what component I've blown
I drive a 2001 honda civic, while driving the other night (doing about 30-40mph) my car suddenly stalled out while in motion with no previous warning of any abnormal temperature fluctuation. Without even realizing what had happened I tried to turn the engine over instinctively. The car turned right over but it sounded a little rough and almost immediately over heated sending off big clouds of burning anti-freeze from under my hood. The car stalled out again and wouldn't turn over after that second attempt. When I checked the radiator I saw no inherent signs of any blown hoses or specific leaks, however all of the fluid was gone. My timing belt appears to still be in place, so I'm guessing that my water pump may have failed? Although I didn't notice any colored smoke coming from my exhaust, I'm wondering if any of these symptoms could be related to my head gasket? Does anybody have any ideas as to what might be the core issue here? To remove this ad, register today for free or log in if already registered!
cow_jive is offline   Reply With Quote
Sponsored Links
Old 09-10-2009   #2 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: 2001 honda civic, trying to diagnos what component I've blown
Hooray double post.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 09-10-2009   #3 (permalink)
speedfoos
speedfoos's Avatar
Head gasket, most definitely. It ate all your coolant and spat it out the exhaust and between the head and the block. Probably has nothing to do with the water pump, but it can't hurt to replace it while you've got the head off.
__________________
www.7thgenhonda.com
Old 09-10-2009   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
engine is prolly toast
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-11-2009   #5 (permalink)
cow_jive
New Member
Crap. Thanks guys, I appreciate it
Old 09-11-2009   #6 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
maybe just need to replace/resurface your head if its not that bad.
04 Honda Civic is offline   Reply With Quote
Old 09-11-2009   #7 (permalink)
speedfoos
speedfoos's Avatar
Engine is probably not toast. Pull the head, take it to a machine shop and have them flycut it (about $50 if they have to pull the valves if you don't) and put a new head gasket on it. Your motor won't start because you don't have any compression. You've got a problem no doubt, but nothing too serious.
__________________
www.7thgenhonda.com
Old 09-11-2009   #8 (permalink)
gearbox
Super Moderator
most places charge around $1k for a head gasket swap and checking for warpage plus getting the head ready by milling and cleaning and compression checks. to me thats worth more than the $600 motor. the block could also be warped too.
__________________
www.lubecontrol.com
Member 1025782
Old 09-11-2009   #9 (permalink)
04 Honda Civic
Super Member
true, I guess it really comes down to whos doing the labor. But even then motor swaps are expensive as well.
Old 09-12-2009   #10 (permalink)
speedfoos
speedfoos's Avatar
I guess I look at it as it will take me about 7 hours to do all the work, $30 for a skim and dip at the machine shop and $35 for a new head gasket. So at $75 ($5 for lunch on the way back from the machine shop each time) and a Saturday, I don't look at it as a serious problem.
__________________
www.7thgenhonda.com
Tags
2001 , 2002 , blown , change , civic , component , engine , gasket , head , honda , identification , locator , replace , replacement , symptoms
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
