Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-08-2009   #1 (permalink)
Maple50175
Senior Member
Maple50175 is an unknown quantity at this point
Best way To Remove Clutch Master Cylinder
So listen to this i'm pretty sure my clutch master cylinder went. First i'll ask my question. What's the best way to remove this. I never knew it excisted in my car due to it being HIDDEN behind the shock tower on the drivers side to the right of the Brake Master Cylinder. I'm scared i'm going to strip that 12mm where the hydrolic line goes into... there is hardly any room to move and I'm not sure what the best way to remove this is? or get it out..
Do i have to remove the Brake master cylinder?
I just ordered a new CMC today for 99 at Honda and I'm hoping to have my car running by tomorrow night.
This is why i think my CMC is gone.... So i was driving all was fine and randomly my clutch peddle would stick to the floor and not come up. I would pull it up and it would be okay. another day the resivoir was low so I filled it up. It felt like there was no pressure on the clutch like i had to push it wayy down for it to engage. So i'm pretty sure its the CMC. I looked at it and where the rubber hose goes into it from the reservoir i see some dampness.
This should fix my problem correct. I swapped out slave cylinders and bought a new line that attaches to it and yeah still has this problem. When i try to bleed it when i have someone pushing peddle there is hardly any fluid comming out. This makes me belive that it's deff the CMC that's bad.
Agree?
sorry i can't spell tonight
__________________
02 Civic Coupe Boosted 8PSI
Maple50175 is offline   Reply With Quote
Sponsored Links
Tags
02 , 06 , 07 , 95 , civic , clutch , cylinder , honda , master , problems , removal , remove , removing , replacing , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
