Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-02-2009   #1 (permalink)
mntbiknfool
New Member
mntbiknfool is an unknown quantity at this point
Is a stiff clutch normal for a Civic?
I recently purchased a 1997 Civic with 82k miles and was surprised at how stiff the clutch pedal was. The stiffness of the clutch is almost comparable to that of the muscle cars I used to drive as a kid! This is a little 4 cylinder...the pressure plate shouldn't be THAT stiff should it!
The previous owner said that both the master and slave clutch cylinders had both been replaced recently. I bleed the clutch today to see if it would help anything and noticed a squeal as the clutch pedal was pressed that appeared to come from within the bell housing. The car has set idle for a while and I am beginning to think that the pressure plate has begun to rust! I mean, the pedal resistance should be proportional to the spring resistance in the pressure plate, correct? So the questions I have are:
1) Is your clutch petal easy to push or hard?
2) Has anyone ever had a similar problem?
Thanks for your time.
Jim
mntbiknfool is offline   Reply With Quote
Sponsored Links
Old 08-03-2009   #2 (permalink)
monkeydave
New Member
monkeydave's Avatar
monkeydave is an unknown quantity at this point
Re: Is a stiff clutch normal for a Civic?
mine is light on 2004 se 1.6 civic
monkeydave is offline   Reply With Quote
Old 08-05-2009   #3 (permalink)
guitarsnroses
New Member
guitarsnroses is an unknown quantity at this point
I have a '96 civic coupe, and the clutch is very easy to push.
__________________
"Conscience does make cowards of us all, and thus the native hue of resolution is sicklied over with the pale cast of thought."
guitarsnroses is offline   Reply With Quote
Old 08-11-2009   #4 (permalink)
Xirkoz
New Member
Xirkoz's Avatar
Xirkoz is an unknown quantity at this point
Maybe they replaced it with an aftermarket clutch, its a possibility?
Xirkoz is offline   Reply With Quote
Old 08-25-2009   #5 (permalink)
cloume77
New Member
cloume77 is an unknown quantity at this point
I had 96 ex, 99 Si, and just bought 04 Si and all three clutch felt/feels pretty smooth and easy.
I agree with Xirkoz comment, previous owner had installed aftermarket clutch...
cloume77 is offline   Reply With Quote
Tags
1996 , 2004 , access , accord , car , civic , clutch , cover , hard , honda , make , pedal , plate , push , stiff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
