Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-05-2009   #1 (permalink)
Memogiyi
New Member
Memogiyi is an unknown quantity at this point
95 honda civic Aic problems and code 14 showing
Hey i have a 95 honda civic lx which i just did an engine swap with the same engine just less miles. When i started it up it up it began misidling between 1000 rpm and 2000 rpm and the check engine light was on. It so happen that i had crossed the two connections with the aic. When i put them the right way the check engine did not turn on till about two minutes but the engine idles even harder. And code 14 keeps showing. I checked the voltage and ohms and everything is fine and in place. Does anyone have any advice? im in need of help! To remove this ad, register today for free or log in if already registered!
Memogiyi is offline   Reply With Quote
Sponsored Links
Tags
14 , 1994 , 2000 , 95 , accord , aic , check , civic , code , engine , honda , light , list , location , problems
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
