Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-05-2009   #1 (permalink)
Jp7
Member
Jp7's Avatar
Jp7 is an unknown quantity at this point
Send a message via AIM to Jp7
Add LED Puddle lights to pretty much any vehicle
I found a new trick, which is a time consuming mod:
Puddle lights, so you can see the ground (or puddles on the ground) when you open your door.
I did this mod in my Evo & my Ranger, It should work on a Civic also.
Pics:
I use PNP transistors to do this. The collector leg to negative terminal of the LEDs, the emitter to chassis ground, and the Base to a 12V switch which is grounded when the door is opened (usually the door ajar signal)
You will have to diode isolate the signal if your doors are in parallel. (The Evo was, Ranger was not)
I'm happy with the results.
__________________
Mitsubishi Lancer Evolution IX MR CT9A (600+BHP/Self Tuned -My old Dyno Video Click Here)
Ford Ranger Edge PN150 3.0 V6 RWD (The Lights & Sound Machine)
Ford Ranger PN150 2.3 I4 RWD (Stock)
Mazda Rx-8 SE3P Single Turbo (Sold)
Mazda Rx-7 FD3S Single Turbo (Sold)
Mazda Rx-7 FC3S Twin Turbo (Sold)
Jp7 is offline   Reply With Quote
Sponsored Links
Old 07-05-2009   #2 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Add LED Puddle lights to pretty much any vehicle
so u ruined a ranger and an evo by adding ricer neons?
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 07-05-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
looks great man, so you did led strips? i have something similar only its just a small trunk lens with 10 red superflux leds inside. its great at night so people dont crash into your door. i just wired mine to the dome light. theyre about 2w each side and my middle dome is a 1w amber led so it all balances to 5w which the stock wires can handle. i didnt do the rears cause they are just never opened.
heres the lens piece i used for the doors, same one thats in the trunk with a 1w red led.
yours light up the ground a ton more but mine are still visible enough and put a good amount of light around the car frame.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 07-05-2009   #4 (permalink)
Jp7
Member
Jp7's Avatar
Quote:
They are LED strips.
Rice = Looks fast and is not. I could lap you 6 times before you got off the line.
Not to mention my clutch costs more than your whole car.
__________________
Old 07-05-2009   #5 (permalink)
Jp7
Member
Jp7's Avatar
Quote:
Yes I used LED waterproof strips. Everything was from oznium.com, they fit great under the hem of the door (only 1/2" tall, and 3/8" wide) - I used OEM style 3M double sticky tape.
__________________
Old 07-05-2009   #6 (permalink)
greeen01civic4d
balls in ur mouth
dont assume, and just because it costs more, doesnt make you cooler, i think ill use some led strips on my balls, that way they will be cooler, o and faster, oooo and even cooler in the internet
__________________
Tags
2009 , add , dome , door , f150 , fit , ford , honda , led , ledforumshondalancer , light , lights , open , puddle , rx8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
