Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-15-2009   #1 (permalink)
97greencivicex
New Member
97greencivicex is an unknown quantity at this point
97 ex car hesitation
i have a 97 civic ex d15b 1.5 and it hesitates mainly when im cruising if i punch the gas pedal it hesitates than takes off but also feels like it has a loss of power .but if i push the gas pedal about half way it hesitates and rpm's drop and feels like its gonna shut off unless i push on the gas pedal all the way then it will go. any advice anyone??????????????????????
i did change the coil, i cleaned the air idle valve, i cleaned the throttle body and i put fuel injector cleaner in the gas tank
97greencivicex is offline   Reply With Quote
Sponsored Links
Old 05-17-2009   #2 (permalink)
Barchiola
New Member
Barchiola will become famous soon enough Barchiola will become famous soon enough
Re: 97 ex car hesitation
i'm having a very similar problem with my 95 EX. I changed the plugs, dist. cap, rotor, coil, and fuel pump but the problem is really that as the car warms up it begins to do what you're talking about.
Some friends of mine tell me that as the car warms up it switches to computer control of the engine and that's when it is miscontrolling the mixture (or something in there). Changing all the ignition stuff made it run perfect when it's cold and made the warm engine stuff more obvious.
I'm told Autozone will hook up a diagnostic reader to your car for free but I haven't gotten around to trying it yet. I'm thinking it could be an o2 sensor, a temp sensor that tells the computer engine temp info, or something else like that. It could also be the computer itself. I was also told to time from a cold start when it starts running rough and that if it is almost exactly at the same point each time then it's related to the computer kicking in to control things.
Check out the threads I posted in the gen 1-5 section or in the main DIY questions thread for Moderator Gearbox who might have an answer.
Good luck,
Bart
Barchiola is offline   Reply With Quote
Tags
1995 , 1996 , 97 , accord , car , civic , cold , dx , engine , hesitates , hesitation , hesitats , honda , losing , power , se
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
