| Re: Cvjoints noise whiles turning wheel to sides dont replace the cv joint. its a waste of time and work. just buy 2 completely new half shafts for your axel.
to remove the half shaft you have to undo the bolt thats between your rims/hubcaps and the tire, undo the lower ball joint, smash out the brake rotor with a hammer so u dislodge the joint, then rip the half shaft out. its a really tight squeeze pulling it out so just break the seal of the boot completely. then put it in and put everything back together.
its a 2 man job, we actually used 3, but a lift is highly recommended |
