Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-15-2007   #1 (permalink)
m_anglim
New Member
m_anglim is an unknown quantity at this point
Problem with my '97- engine reving on it's own! Help!
Okay, I've got a '97 with 224k miles on it and I love my car but today it has started giving me fits. It is reving by itself. I am wondering if anyone can tell me what could be causing this and if there are any quick fixes I could try before I have to find a repair guy. I just moved to a new town and am not looking forward to finding a new mechanic.
Did have codes checked- only O-2 sensor which has been going on for a year and I haven't replaced. Doesn't seem to be the belts. Did notice that the radiator fluid is low- I will replace, but could this affect it at all? Also have had unusually low temps (weather, not car)- car seems to have adjusted well and is starting fine. Have noticed that the door seals are breaking down and that there is a lot of moisture on the inside of the windshield- could moisture be getting into any other places that might affect this?
All practical advice would be much appreciated!!!!!
m_anglim is offline   Reply With Quote
Sponsored Links
Old 01-15-2007   #2 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
I assume you're saying that your car revs high while it idles.
Your idle is controlled by your IACV which is either on your throttle body if you have an auto or DX/LX. It'll be on the back of your IM if you have a 5 speed EX. Coolant runs through this controller so it knows if your car is warmed up or not. So yes, being low on coolant could cause an idling malfunction. It could also be that your coolant is not circulating through the IACV.
You should also replace your O2 sensor immediately. There are 2 of them. The code from the CEL will tell you which one is bad. They control your fuel/air mixture so if one or more have gone bad, the computer will switch over to fixed setting or run lean (bad for engine). Once you clear this CEL you should look for another code that might be related to your idling problem.
sql_civic is offline   Reply With Quote
Old 01-17-2007   #3 (permalink)
stl01civic
BOOSTED DOHC i-VTEC
stl01civic's Avatar
stl01civic is an unknown quantity at this point
check the engine bay and see if any vaccum hose are loose.
__________________
06 STi - 309.1AWHP 360.7TQ - Stage 2
01 Civic -239.8WHP 212TQ @ 7.5psi
stl01civic is offline   Reply With Quote
Old 01-20-2007   #4 (permalink)
PCBKnight
New Member
PCBKnight's Avatar
PCBKnight is on a distinguished road
Send a message via AIM to PCBKnight Send a message via Yahoo to PCBKnight
I have a problem with my civic idling up and down. It does not do it all the time but it does enough to be annoying. My map sensor is my problem. This could be your problem. If it is idling real high it could be your throttle position sensor. You could also take the prior advice as it could be a vaccum leak which my mechanic friend said it sounds like the problem to him. Good luck man and if it is a sensor go on ebay cause it will cost you out tha a** for them in the parts store. I know personally. Civics are gold nuggets...lol. Keep us posted on it man.
PCBKnight is offline   Reply With Quote
Old 01-21-2007   #5 (permalink)
PCBKnight
New Member
PCBKnight's Avatar
Thought I'd let you know that mechanics don't always know what they are talking about. My map sensor is not my problem. Try taking your idle air control valve apart and cleaning it with brake parts cleaner. I forgot that I used to have the problem on my old corsica and that is what I did and it worked fine after that.
Old 01-21-2007   #6 (permalink)
black02seavik
Member
black02seavik's Avatar
black02seavik will become famous soon enough
224 k damn thats insane
black02seavik is offline   Reply With Quote
Old 01-31-2007   #7 (permalink)
n/a-efhybrid
New Member
n/a-efhybrid is an unknown quantity at this point
The low coolant and IACV would be the two things I'd look at.
n/a-efhybrid is offline   Reply With Quote
Old 02-01-2007   #8 (permalink)
sentbacktothesu
Member
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
Send a message via AIM to sentbacktothesu
My friends integra did that, it was the coolant, but he needed a new rad.
sentbacktothesu is offline   Reply With Quote
Old 03-08-2007   #9 (permalink)
jweb42055
New Member
jweb42055 is an unknown quantity at this point
you may want to check your throttle body gasket for a leek, same thing happened last week when i tried to put in a throttle body spacer, the idle went crazy 4000 for 15 sec then go between 2500 and 35 when idleing, check your gasket could be leaking, when i took mine out the old gasket looked like it was close to leaking, but i had to put the old one back because i couldn't get the throttle body spacer tight, we'll try again this weekend,
Nice to hear someones got as many miles as me 223k on my 96
jweb42055 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
High Pitch Rubbing Sound When Reving Engine Jasdip Mechanical Problems/Vehicle Issues and Fix-it Forum 0 10-23-2006 01:39 PM
High Reving Engine? TransformedBG Honda Civic DIYs and Civic Tech Chat 7 06-03-2005 08:04 AM
Reving up engine asdfasdf Honda Civic DIYs and Civic Tech Chat 43 05-21-2004 05:45 PM
What's it about REVING AT ME!!!!!!!!!! GreenVenom General Automotive Discussion 14 08-06-2002 03:58 PM
Why are you reving at me ????? APS General Automotive Discussion 25 03-31-2002 01:59 AM
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
Replacing Headlight Assembly/Bulbs
How much have you spent on your civic?
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Manual or Auto
ignition coil
It's CONTEST TIME!!!
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
