Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-15-2006   #1 (permalink)
civicexracer
New Member
civicexracer's Avatar
civicexracer is on a distinguished road
magnetic oil/tranny plugs?
I was looking around on some part sites and stumbled upon these oil and tranny plugs that have a magnet on the tips of them. apparently they are to collect small, loose metalic particles that flow thru the engines fluids. they claim to extend the life of the engine and tranny. ur supposed to put them in with the next oil change/tranny fluid change and im gena be changing my oil soon and might have to change the tranny fluid as well(need to check that) Has anyone heard of these or have them? do u think it actully works? i know they arnt gena make a dramatic difference but anything can help...esp. on an old engine. any feedback on this is greatly appreciated.
thanks
heres a pic of what they look like:
__________________
Proud member of Rubber Duckie Racing
www.teamrevctc.com
www.mdstreetscene.com/forum
civicexracer is offline   Reply With Quote
Sponsored Links
Old 03-15-2006   #2 (permalink)
Wadely
Senior Member
Wadely is an unknown quantity at this point
Send a message via AIM to Wadely Send a message via Yahoo to Wadely
yea
Well i work for honda and the tranny drain plug is already magnetically designed to cath metal shavings, the oil drain plug is not magnetic but as long as you change your oil on time metal shavings in the oil are not going to occur and even if you werent on time with oil changes its likely there still would be no metal shavings, you would have to run 2-3 courts low before the friction gets harsh enough to shave any kind of metal.
Wadely is offline   Reply With Quote
Old 03-26-2007   #3 (permalink)
baja74vw
New Member
baja74vw is an unknown quantity at this point
Re: magnetic oil/tranny plugs?
I can actually guarantee they work! They have been around since the 30’s and have never left. The ASE recommends them. Funny I found this thread, since this is close to my heart!
You will always find particles on you magnetic drain plug. Doesn't matter what the oil level is. Normal wear does allow metal to float through the oil. Use a magnetic drain plug for one oil change and you will see! I have on in every vehicle and have seen some interesting things. Not worth cutting down.
Tim
__________________
Try our new application search!
www.magneticdrainplug.com
baja74vw is offline   Reply With Quote
Tags
2001 , 2004 , 2006 , 2009 , change , civic , drain , honda , magnetic , metal , oil , pictures , plug , plugs , shaving , shavings
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
