Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
View Poll Results: My Civic is...
Automatic 74 28.68%
Manual 184 71.32%
Voters: 258. You may not vote on this poll
LinkBack Thread Tools
Old 04-15-2006   #31 (permalink)
Smooth
Junior Member
Smooth is on a distinguished road
Well I just "learned" to drive MT. I pretty much knew how to drive it and what to do the basics but I actually got to try them out now. I drove my brothers Nissan Altima and practiced on that. I didn't think I would hate it soo much cuz I hate stalling. But I think I did pretty good for my first time ony stalled twice. To remove this ad, register today for free or log in if already registered!
Smooth is offline   Reply With Quote
Sponsored Links
Old 04-16-2006   #32 (permalink)
GoneIn60
Member
GoneIn60 is an unknown quantity at this point
Send a message via AIM to GoneIn60
thats good i remember my first time my dad took me on all these hills and it was tough at first but now i can beast them up. Has anyone ever drove one of those transmanual transmissions where all you do is push up or down to change gears?
__________________
01' civc lx
i/h/e
ex head swap w/ vafc2
crower stage 2 camshaft
crower stage 2 valve retainer and springs
GoneIn60 is offline   Reply With Quote
Old 04-17-2006   #33 (permalink)
05blkrs
Senior Member
05blkrs is an unknown quantity at this point
Quote:
ok just read this thread for the first time and have a couple of points... first, the "transmanual" thing... are you refering to the type like in the mr2 spyders where it's automatic but you have to shift it? i like those my friend has an mr2.. it's similar to an exotic sports car sequential trans... the mr2 also has the buttons on the steering wheel to change up and down... for double clutching, that was a descent explaination... it was acurate, but here is an in depth write up... check it out http://www.driftstars.com/forums/showthread.php?t=72
as far as the grinding at high rpms, that means your syncros aren't doing their ob correctly.. i had the same problem in my mazda, and it got worse and worse.... after a while, it wouldn't even go into third w/o grinding unless i double clutched.. even at like 4krpms... the syncros were shot... and as far as m/t swaps in civics, you have to add the pedal, shifter assemblies w/ all the connections, hoses linkage etc... the axles (i think it may be only one of them on a civic) will have to be changed, and on a b and d series civic motor, you will have to modify your starter wiring harness as the starter is in a diff. location.. i'm not sure if the starter its self has to be changed or not..its not too hard most of the stuff like shifter linkage and stuff like pedals are available at junk yards, so over all materials cost should be about $200 after buying the trans, clutch and flywheel... ihad one i sold for $150.... anyone w/ normal tools should be able to do it in a driveway in a weekend..
05blkrs is offline   Reply With Quote
Old 04-17-2006   #34 (permalink)
GoneIn60
Member
yea some of the new eclispes have them and those mr2 spyders. As far as the gear grinding stuff using oem honda manual transmission fluid helpped alot no grinding at high rpm's. The only problem i found out with my tranny is that in 2nd sometimes it pops out when im decellerating. I found that there is a honda TSB to fix it but my warranty is up so im prolly not gonna get it fixed, i mean it still shifts fine its just sometimes it likes to pop out occasionally
__________________
01' civc lx
i/h/e
Old 04-17-2006   #35 (permalink)
05blkrs
Senior Member
replace your bushings... they are on the solid part of the shift linkage that just mounts on the trans that doesn't ever move... get some urethane bushings it should help out... also on the double clutching being from f&f thing, there are two types of double clutching... it should be covered in that link i posted.
Old 04-18-2006   #36 (permalink)
GoneIn60
Member
ah thanks good call on the bushings
__________________
01' civc lx
i/h/e
Old 04-18-2006   #37 (permalink)
Rokki
Member
Rokki is on a distinguished road
Manual. It made the car so much zippier. I loved it. It was a little tiring, however, because the seat didn't move up quite far enough and it was a stretch to work the clutch.
Rokki is offline   Reply With Quote
Old 04-19-2006   #38 (permalink)
JewelBeetle
Junior Member
JewelBeetle is on a distinguished road
My husband's '98 Civic was a manual. He already owned the car when I met him, and I only knew how to drive an automatic. I tried to drive a manual a few times, but I didn't stick with it, and I wish that I would have. I was basically a passenger in our Civic.
JewelBeetle is offline   Reply With Quote
Old 04-20-2006   #39 (permalink)
Rokki
Member
For those of you driving a manual, do you ride your clutch? I have a tendancy to sit on the clutch instead of the brake so that I can move faster when the light turns green.
Old 04-20-2006   #40 (permalink)
Rokki
Member
Quote:
My parents taught me to drive on a manual. It was hard on all the hills, but I'm glad I learned. Sports cars are much better served with a manual transmission.
Why didn't you stick with it?
Old 04-20-2006   #41 (permalink)
CharlieLink
Member
CharlieLink is an unknown quantity at this point
Manual
My 5-speed arrived Monday. I had mentioned earlier on this thread (post #2) that I didn't like the low torque on Omaha hills when I test drove the automatic. Same hills - the stick is much better!
CharlieLink is offline   Reply With Quote
Old 04-21-2006   #42 (permalink)
05blkrs
Senior Member
i almost bought a scion tc when they first came out but they had a 2 month waiting list on a manual so i got that mazda i had instead
Old 05-01-2007   #43 (permalink)
BlueRevs
Super Member
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
Send a message via AIM to BlueRevs
Re: Manual or Auto
Manual
__________________
2007 Satin White Pearl on Bronze BBS Impreza WRX STi
BlueRevs is offline   Reply With Quote
Old 05-03-2007   #44 (permalink)
lazyxness
New Member
lazyxness is an unknown quantity at this point
Send a message via AIM to lazyxness
Re: Manual or Auto
Quote:
Originally Posted by anteater View Post
Is your Civic manual or automatic?
And which do you prefer overall?
i have a 2003 LX manual =) and i love the manual
lazyxness is offline   Reply With Quote
Old 05-10-2007   #45 (permalink)
HighBoost
Member
HighBoost's Avatar
HighBoost is an unknown quantity at this point
Send a message via AIM to HighBoost
Re: Manual or Auto
Manual maan !! Auto tran EM civic r so weak.. and auto wont produce more boost than manual under exact same set up
HighBoost is offline   Reply With Quote
Tags
auto , civic , manualto
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
