Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-26-2006   #1 (permalink)
imported_Mikey
Member
imported_Mikey is an unknown quantity at this point
$5000 supercharger conversion
I found this, its an English site but they also list the cost in $USD.
http://www.tts-performance.com/civicsupercharged.php
It looks awesome. I've always wanted to supercharge my car and I think one of these kits would do it well.
They got a big power increase there
imported_Mikey is offline   Reply With Quote
Sponsored Links
Old 02-26-2006   #2 (permalink)
Tayler
Senior Member
Tayler is on a distinguished road
You would get alot more for your money from a turbo. Go to www.evans-tuning.com, and go to the forum and then dyno charts. Look at there setups and ask them questions about how much they spent and whatever else you want to learn. Because for five and a half grand, you could do all your internals, buy a good turbo, all the other crap that you need and make like 350-450 whp instead of 300. The key with a turbo though is to get a turbo that is made for your cars powerband.
__________________
New project-D16z6
Tayler is offline   Reply With Quote
Old 02-26-2006   #3 (permalink)
CG99
Member
CG99 is an unknown quantity at this point
And they will both stress the engine, I still think the turbo will stress it more though depending what boost you run it at.
Yes a turbo will be faster, but a supercharger is nice as it wont stress the engine as much and will work just as well even if the engine doesnt put out big power like the civic.
Also with a turbo youd want to upgrade internals straight away but you could get away with not doing that if using a supercharger.
CG99 is offline   Reply With Quote
Old 03-05-2006   #4 (permalink)
Darth
Member
Darth is an unknown quantity at this point
better than one of those stupid turbonator $70 "superchargers" anyway.. if it costs $5k surely its got to be of some quality?
Darth is offline   Reply With Quote
Old 03-05-2006   #5 (permalink)
option2
Member
option2 is on a distinguished road
Acctually superchargers put more stress on the rotating assembly/drive train as they make alot of lowwer end torque, thats especially hard on axles. They also sap power from the engine as you have to power the s/c off the pulleys to generate positive pressure, with that your taking power from the engine, similar to A/C and power steering. Turbochargers on the other hand use free power that would otherwise be put to waste (exhaust heat/pressure). You dont 'have' to upgrade internals with a turbo as compared to an s/c, 8psi is the same from a turbo as it is from a supercharger. Id honestly go turbo, but hey, im a turbo guy, i have one tattood on my leg for ****s sakes
option2 is offline   Reply With Quote
Old 05-15-2006   #6 (permalink)
imported_Mikey
Member
superchargers use engine power, hence more stress on the engine components than a turbo which uses exhaust gases.
You have a turbo tat on your leg?? haha, can you post a pic?
Old 05-16-2006   #7 (permalink)
05blkrs
Senior Member
05blkrs is an unknown quantity at this point
FIRST OF ALL EVERYONE, this is a very common mis conception about turbos.. it's not the psi that matters it's the cfm of flow.. my friend had a td04 turbo(fairly small stock turbo) on his wrx running 21 psi.. he then, upgraded to a larger vf30 turbo, and ran around 19 psi.and made more power.. hence, you can run the same psi or less on a larger turbo that flows more air, and get more boost... so people saying you can run 8psi on stock internals are full of crap.. because if i go get an 81 trim turbo and run 8 psi on my car, it will blow it all to hell... now if you say you can run a small turbo at 8psi on stock internals, i say you're right.. i say turbo because it is much more efficient, much better on gas etc etc. on a turbo set up, you can go easy on the throttle, and all that, and you will usually see an IMPROVEMENT on gas mileage.. plus, turbos dont have that annoying whine to them
05blkrs is offline   Reply With Quote
Old 05-16-2006   #8 (permalink)
imported_Mikey
Member
Annoying whine?
I think everyone loves that sound.. I sure dont call it an annoying whine!!
Thanks for that info though, you sound like you know what you're talking about
Tags
2006 , 5000 , civic , diesel , honda , sale , supercharge , superchargers , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
