Quote:
Originally Posted by twinkle Flush radiator and refill
Flush brake fluid - replace with ATE Superblue
Change MTF - replace with Honda MTF
Change rear pads - replace with Honda pads
Change clutch fluid - Replace with DOT 4 brake fluid, make sure you flush and bleed it properly
Change power steering fluid
Tires - Check Alingment
Check Fuel Filter if not Already Changed
Inspect Belts for Wear and Tear but should be good to 100k |
The radiator should have already been done before this anyway. Do it again if you want.
ATE Superblue - where did you get that info from?
