Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum
General Honda Civic Forum General Honda Civic Forum - This is the place for general Honda Civic discussion. If you have questions about the history or future of Honda Civics, factory specs for the Honda Civic, or other general Honda Civic Questions.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-22-2006   #1 (permalink)
imported_Sam
Member
imported_Sam is on a distinguished road
Turbo or N/A?
I have a B16a Civic, but of course I find it a little sluggish at times and I often wish for more power.
In your opinions, should I save up for a turbo kit and hook all that up, or just upgrade everything a bit at a time and have a killer N/A?
imported_Sam is offline   Reply With Quote
Sponsored Links
Old 01-24-2006   #2 (permalink)
vtec12
Member
vtec12 is an unknown quantity at this point
Depends what you want really. Turbo's give a nice rush but an NA Honda thats worked sounds out of this world.
Personally I love an NA VTEC engine - and I'd go for that anyday over a turbo.
but if you want the turbo sound and more power, then go that route instead.
vtec12 is offline   Reply With Quote
Old 01-30-2006   #3 (permalink)
Tayler
Senior Member
Tayler is on a distinguished road
Oh man you guys, if you want to save up 2500 or better turbo your car. A good turbo setup will easily cost you over 3k after you get forged pistons, rods, valve springs a retainers, turbo, downpipe, manifold, bov, flanges, and all that good stuff. My car is all motor and probably has around 5k or better in mods. But i like that because i dont have to worry about it breaking.
__________________
New project-D16z6
Tayler is offline   Reply With Quote
Old 01-31-2006   #4 (permalink)
twinkle
Member
twinkle is on a distinguished road
I think most turbo packages are over-rated. They will give you slight acceleration but no real top end improvement and you will have a lot of wear and tear on some parts. It is likely you will be replacing your transmission much sooner, for example.
twinkle is offline   Reply With Quote
Old 02-01-2006   #5 (permalink)
imported_Sam
Member
heh turbo's give more than just slight acceleration.. more like a big kick in the pants and head back in the seat.
As for upgrading internals when you turbocharge the car, yes you should do it I know and its pricey.
You CAN do the upgrade without internal upgrades I know, but I realise the car will not last very long like this.
Old 02-02-2006   #6 (permalink)
imported_raven
Junior Member
imported_raven is on a distinguished road
turbo
I saw this thread on turbos and decided to share a website that I recently found.
http://www.turbonator.com/index.html
It seems legit enough, please tell me your thoughts.
imported_raven is offline   Reply With Quote
Old 02-03-2006   #7 (permalink)
Tayler
Senior Member
Not only will it not last very long but you would be limited to running 8-12 psi with a small turbo only putting out low 200 whp. With forged internals depending on what you had you could be runnin 15-22 psi and make like mid 350 whp with a more efficient turbo.
__________________
New project-D16z6
Old 02-03-2006   #8 (permalink)
twinkle
Member
Quote:
No way you modding yourself to 350 whp for anything less than a huge amount of money.
I could make my car fly if I spent enough money on it.
Old 05-03-2006   #9 (permalink)
imported_Sam
Member
Thanks for the advice
Thats what i thought.
Looks like i have some serious saving to do
Old 05-27-2006   #10 (permalink)
vargasr66
New Member
vargasr66 is an unknown quantity at this point
either way you go your looking to spend a good amount of money. If you know what you are doing you can piece a turbo system together out of salvage parts.. less expensive.. and you can run stock internals with a low boost system and be fine. the problem with running stock internals is that the "speed bug" bites you and and people will normally go crazy with the boost pressure and that's where you get into trouble. think of it like this ...car manufacturers don't spend extra money on an engine that comes stock w/ turbo. all the engines are the same ie. no upgraded internals, head gaskets, nothing to help the engine out at all. still they run just fine as long as you don't do anything dumb like try and add more boost to a designed system.. Buying newwould be your best bet and most aftermarket places will help you with what you need (if you build it up or keep it stock)..
vargasr66 is offline   Reply With Quote
Old 05-29-2006   #11 (permalink)
Tayler
Senior Member
Forged internals, rods, valvetrain, pistons=1200
Basic turbo kit=2500-3000
wide band, safc, chipped ecu=800-1000
Right there your at 5 grand, that is a huge amount of money and it can be done.
__________________
New project-D16z6
Old 05-29-2006   #12 (permalink)
imported_Tricky
Member
imported_Tricky's Avatar
imported_Tricky is on a distinguished road
5k isnt a huge amount of money. What can you get for 5k?
An old bomb car. Or you could build yourself a virtually brand new engine that will probably last you for 10 years.
In that sense 5k is nothing.
imported_Tricky is offline   Reply With Quote
Old 06-05-2006   #13 (permalink)
fatboycg
Junior Member
fatboycg is on a distinguished road
Send a message via AIM to fatboycg
if you want to turbo that thing with less than a grand i can help you and give you light on peices hit me up on aim.
fatboycg is offline   Reply With Quote
Old 06-05-2006   #14 (permalink)
Darth
Member
Darth is an unknown quantity at this point
Quote:
Shameless self promotion
can you post here how to safely turbo a civic for under $1000?
Im sure we'd all love to hear how
Darth is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
How much have you spent on your civic?
Manual or Auto
I Got 2 ECU Codes P1298 and P1519
Finding the ECU error codes
2010 Honda Accord Diesel
Replacing Headlight Assembly/Bulbs
It's CONTEST TIME!!!
ignition coil
Civic 2007 Typr-R
Site Supporters
aluminum radiator
Honda car spoilers
