What kind of ATF should I use??
Old 05-18-2003
CivicPro01's Avatar
CivicPro01 is an unknown quantity at this point
Well, I have a 2001 civic auto. and it has around 34k miles and i drive my car pretty hard so i need to replace my atf. but i need to know which kind is the best and where can i get it??? I heard some people using mobile 1, the honda kind, and quaker state. thanks
CivicPro01 is offline
Old 05-18-2003
flotsamm's Avatar
Why not just use Honda ATF again?
flotsamm is offline
Old 05-18-2003
ekwc's Avatar
ekwc is an unknown quantity at this point
Try Mobile-1 ATF, my car has it and it runs very smooth. Make sure to clean the magnetic drain plug, I bet it will be very dirty (after you running your car for 34K miles). Good luck.
ekwc is offline
Old 05-18-2003
klam's Avatar
klam is an unknown quantity at this point
I just changed mine to Honda's Z1 ATF. Honda has different specifications for its ATF than other manufacturers. Most other manufacturers use Dexron III type ATF, while Honda and Chrysler use their own formulation.
klam is offline
Old 05-18-2003
Its a celebration bitches!
HondaLuver's Avatar
synthetic
HondaLuver is offline
Old 05-18-2003
CivicPro01's Avatar
alrite thanks but could u guys give me more info. on the synthetic kind?? and well there is a problem buying the honda kind b/c then i have to drive about an hour away to get to the honda dealer and buy the atf fluid.
Old 05-19-2003
klam's Avatar
Here is a good link from an Acura Vigor enthusiast club. The information is quite relevant.
http://pw1.netcom.com/~gentile/Vigor/Timely0102.htm
klam is offline
Old 05-19-2003
ak
Retired Mod
ak's Avatar
ak can only hope to improve
wow, that's a great link.
Use HONDA ATF.
ak is offline
Old 05-19-2003
HondaLuver's Avatar
Im using Motul synthetic ATF and my car runs perfectly, you should be changeing your ATF every 30,000, I change my motor oil every 3,000 with Motul Synthetic. its one of the best brands out there
From the Vigor site...
"Second, Acura recommends using genuine "Honda Premium Formula Automatic Transmission Fluid or an equivalent DEXRONŽ II Automatic Transmission Fluid (ATF) only." Many club members reported harsh shifting problems that were fixed by changing over to Honda's ATF. Apparently, the difference is significant enough that we recommend using only genuine Honda ATF."
Old 05-19-2003
CivicPro01's Avatar
so the verdict is honda or mobile 1???
Old 05-20-2003
klam's Avatar
I think the risk-free way to go is Honda's Z1 ATF.
klam is offline
UltraHDGames
06-08-2016 05:16 PM
Zygrene
03-22-2016 12:36 PM
ken4444
09-30-2015 07:37 PM
rovafa2002
09-28-2015 06:57 PM
Quick Reply: What kind of ATF should I use??
