Code # P1456.......
Old 01-23-2003
Extreme Member
ZSKCivic01's Avatar
ZSKCivic01 is an unknown quantity at this point
Code # P1456.......
Hey everyone, just got back from autozone since my check engine light was on and they found after checking my ecu that the code # for the problem was P1456. Honda told me that this was the code for an evaporative leak, aka Gas cap loose. Well, my gas cap hasn't been loose since yesterday when I tightened it up. It was kind of loose before, because I could smell gas around it, but the light is still on even though the gas cap is tightened. Do I need to reset the ECU or do I need to take it to honda to see if something else is leaking? I went under my car and couldn't smell any gas fumes. Honda said they would charge $70 to check it out, and I personally don't want to spend all that money. I would really appreicate your help!
ZSKCivic01 is offline
Old 01-23-2003
Gizmo's Avatar
Gizmo is an unknown quantity at this point
You can try resetting the ecu, to my knowledge it does not hurt anything anyways.
Gizmo is offline
Old 01-23-2003
mikalem's Avatar
mikalem is on a distinguished road
It's probably a keep alive code, where even if the problem is fixed it stays in memory until a dealership looks at it and removes it or you do it yourself. Simply removing the battery might not do it for you - you might need have autozone use their reader and delete it.
mikalem is offline
Old 01-23-2003
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
if it got loose enough to turn light on, then it will take a while of driving for it to turn off, i drove a few days w/o cap and it went on, took a few days to go off too
mykungfuisthebest is offline
Old 01-23-2003
Extreme Member
ZSKCivic01's Avatar
n/m, I disconnected my battery and after I reconnected it, the light went off so im good now!
Old 08-07-2009
Backer54's Avatar
Backer54 is an unknown quantity at this point
Re: Code # P1456.......
Not a big deal. A lot of the civics and CRVs have caps that go bad. Autozone or the like have replacements. It take 50 cranks for it to reset. If it doesn't then get it checked again. Disconnecting the battery doesn't always work. Outside temperature seems to be a cause as well because of expansion and contraction of either the plastic or the metal on the body. Either way, no big deal unless you're trying to get through instection that day! Just keep an eye in it and if you have a good mechanic, have them clear the code for you.
Backer54 is offline
Old 08-07-2009
MidnightCivic's Avatar
Should usually take off after driving a while..
MidnightCivic is offline
SimpleUser
04-24-2021 02:54 AM
Civic15
18
09-19-2017 07:48 PM
Dangerousjordan
07-30-2015 11:19 AM
jessica19699
07-29-2015 05:51 AM
Green02civic
07-27-2015 10:48 PM
Quick Reply: Code # P1456.......
