Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum Archive.
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 12-13-2002   #1 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
Send a message via AIM to OsOBooSTeD Send a message via Yahoo to OsOBooSTeD
Dash light color change question:
ok heres the deal.. the read everthing i can on how to change the dash lights (a/c controls etc.) i took apart everything in my car too.. just to get a look at what im dealing with... i used the bulb condoms that i got from my best friends 240sx.. well color looks green now thanks to NISSAN.. lol but i have reverse indiglo gauges so green isnt GOOD... well after carefull THINKING lol.. i was wondering if i could just go buy a binder from walgreens .. one of those seee through plastic ones and just cut them and lay them in there instead of the gel things which i cant seem to find anywhere side from online. But let me know if you think this is a good idea.. i mean the binders come in purple, yellow, blue, red , green.. and they're all see thro for $1 each..MY QUESTION IS will the plastic heat up too much if i do this?
OsOBooSTeD is offline
Old 12-13-2002   #2 (permalink)
Crashoveride's Avatar
Points: 12,346, Level: 72
Points: 12,346, Level: 72 Points: 12,346, Level: 72 Points: 12,346, Level: 72
Level up: 74%, 104 Points needed
Level up: 74% Level up: 74% Level up: 74%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Images: 25
Crashoveride is an unknown quantity at this point
Send a message via MSN to Crashoveride
Whats the question .........
Crashoveride is offline
Old 12-13-2002   #3 (permalink)
AEMcivic is an unknown quantity at this point
Send a message via AIM to AEMcivic
I tried the binder thing, and it worked a little bit, but they weren't nearly as blue(or bright) as I wanted them. They might start to melt of you leave your lights on for long periods of time. When I took em out they showed now signs of melting or anthing.....but they were only in there for a few days, and I only drive with my lights on at night. After that I soldered in some blut Varad LEDs and a 500ohm resistor. Now they match my reverse indiglo guages perfect. If you knwo how to solder, it's not that hard to change the lights. You just gotta be patient and take your time.
AEMcivic is offline
Old 12-13-2002   #4 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
OH shiv... good idea..Im going to radio shack now[IMG]i/expressions/laugh2.gif[/IMG] Your the MAN 500 ohm is right size?
Old 12-13-2002   #5 (permalink)
It depends. I used Varad LEDs that came connected to a circuit board that made them blink. There was about 500ohms of resistance through that circuit board because the LEDs would burn out with straight 12v current. Radio Shack might have 12v LEDs that won't burn. If you want, you can try them out with a 500ohm resistor....if they aren't bright enough, bump the resistance down a bit. If you have the extra money, it's always good to buy an extra LED to test out first.
AEMcivic is offline
Old 12-13-2002   #6 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
ok bet... but what size LED ? i think they come in like 5mm 10 uh 3
Old 12-13-2002   #7 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
look at this would this be good?
or this one?
here
how do u determin the resistor?
Old 12-13-2002   #8 (permalink)
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
Send a message via AIM to Bogus1
If you read theDIY on how to change the dashlight color it says
Posted by AlpineCivic on Monday October 08, 2001 9:10:09 AM
Quote:
Quote
[hr]The LED indicators can b replaced with Radio Shack Blue or any other color LED I did not test current on the led my best guess would be 2-3 volts but to be safe add a 880 ohm reststor to the posistive side of the led if it don't light up remove the resistor.[hr]
Bogus1 is offline
Old 12-13-2002   #9 (permalink)
Either one of those looks good. I'm pretty sure mine are 5mm.
As for the resistance.....I'm sure there's some formula that will tell you, but I just messed around with it until I found the right brightness without the LED burning. (I went through 2 or 3 LEDs) Talk to the guy at Radio Shack....he might be able to tell you. I'd get the LEDs on the first link, and maybe start out with a 300ohm (or something around that number) resistor. Also, make sure you solder the wires, resistors, and LEDs to make sure all your connections are good. Here's a pic of mine when everything was finished....
Click the image to open in full size.
AEMcivic is offline
Old 12-13-2002   #10 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
how do u know which side of the led is positive?
Old 12-13-2002   #11 (permalink)
Depending on what kind you buy, they may be marked. If they aren't just grab a 12v battery, hold a resistor on the positive terminal, then touch one lead from the LED on the negative terminal of the battery, and touch the other lead to the other end of the resistor. You can only hook them up one way, so if it lights up, note which lead was touched to the resistor because that's the positive lead. If it doesn't light up, then swap the leads around and it should work.
AEMcivic is offline
Old 12-13-2002   #12 (permalink)
OsOBaNNeD
OsOBooSTeD's Avatar
all i have to say is 20 minutes 10 bucks and i got a bluish purple dash very nice thanks
Old 12-13-2002
CivicForums
Honda Civic
Paid Advertisement
Tags
07 , 2001 , 2006 , burnt , change , civic , color , dash , honda , led , light , lights , purple , size , speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
60,000 mile Transmission fluid change
Looking for a 7th gen manual for free? (UPDATED!!!)
SOHC VTEC Explained
AC Recharge kit overcharged my system! What now?
ALL of Grey's DIY's...
Oil Changes
Removing door panel from a 2002 civic
Detailed smoked out taillights DIY w/ pictures
Automatic Transmission Flush
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
