my 2000 honda civic si will not start at all
Rep Power: 0 my 2000 honda civic si will not start at all
i worked on my civic 4 5 days n it wont start.we did a full tune up new spark plugs,plug wires,distributor etc.new pcv valve,fixed da timing belt n tensioner new belt also even a brand new battery.my car died on me a few months ago n due 2 money issues it took me a while to get 2 fixin it.it seems im spendin money on unneccessary stuff but i have tried everythin i can think off.starter fluid in da intake,disconnecting da muffler at da flex pipe even tryin 2 jump start the car.any suggestions any ideas me n my buddies are all out.please help
Rep Power: 0 Re: my 2000 honda civic si will not start at all
****, did i just feed another troll?
Well, i'm bored, so ill continue.
You need three things for fuel ignition (4 in an internal combustion engine, ill get to that later)
1: FUEL, you should have fuel unless the ecu somehow doesn't know when to inject the fuel, or no fuel in the tank or bad fuel pump.
2: AIR, theres really no way not to get air unless you stop up the intake.
3: SPARK, easy to check for, hard to find if it doesn't spark.
4: COMPRESSION, this is necessary in an engine because it wont expand enough if the air isn't compressed.
Check the fuel pump, personally i would just pull it and bench test it, but there may be more ways.
Timing may be off.
Any CELS?
PLEASE type like a normal person, I wont help you anymore if you don't use proper English, ill assume you're a troll, and flag you.
Timing may be off.
Any CELS?
I was going to say crank position sensor, but if you don't have a CEL it must've went out while it was shut off, it could also be unplugged, you never know.
I'd try to get a junkyard one, since they are pretty expensive and see if it fixes it.
oh ok im sorry well we took the crankshaft position sensor off and were searching around for a new one so were hoping thatz all it is and that it will start
Dr Krieger of Modification
even if the cel is not on i'd suggest trying to pull codes from it. you never know if the LED is dead or if the problem is also causing the electronics to not work, it could save you a lot of time.
secondly what happens when you turn the key?
when i turn the key it does crank the engine the engine wants to turn on.but it seems like something is not giving the motor enough spark.we hooked a obd2 to it and it read the code which we looked up and we figured out about the crankshaft sensor
ok so she wont start. all the things were checked and still the same result. check the ground at the motor, the batt, or the main relay. those are most of the main problems why hondas wont start.
yea whoever owned the car before me obviously didnt take care of the car the cam gears had skipped a tooth because the tensioner was just hanging on without a bolt on it
Whachya lookin at?
Rep Power: 288 Re: my 2000 honda civic si will not start at all
You could have some major internal issues from the timing being out of whack. When you changed the belt did you make sure ALL the marks were properly lined up?
yea we took a full day and a half to make sure everything is in proper order and that everything was lined up properly right now we are waiting for the crankshaft position sensor to come in the mail
yea we did a compression check and everything seem fine we bought a new pcv valve plus hose to make sure we checked the valves n pistons while doing the timing and that seem good too
Whachya lookin at?
Sounds like everything overly expensive has been ruled out which is good. Good luck with the sensor, hopefully it gets it going.
jessicakaybby
04-20-2015 12:11 PM
civic_gt
04-19-2015 08:15 AM
gabrown2
04-11-2015 08:22 PM
