2001 civic intermediately runs rough
Old 04-06-2010
radar1's Avatar
radar1 is an unknown quantity at this point
Have a 01 civic with auto tranny. Almost daily when I start it within a minute it will run like it's out of gas, but only after I drive about 50ft.. I can shut it off and immediately turn it back on and it will run just fine. It doesn't matter hot or cold, and it doen't do it every time but at least daily. It will run so bad that it will not pull itself. I have been able to put it in park and after a few minutes it will clear up and be good to go. No lights showing up and the computer is showing no codes. Any ideas???
radar1 is offline
Old 04-06-2010
lowlife9's Avatar
Re: 2001 civic intermediately runs rough
maybe change the fuel filter and get a tune up like plugs,air filter and maybe try a fuel suystem cleaner like tecron or gumont.
lowlife9 is offline
Old 04-07-2010
rzc
rzc's Avatar
rzc is an unknown quantity at this point
I had to get new coilpacks back when... and also did use the techron which cleaned up whatever gunk it was then. I switched back to NGK as suggested in the link below. Still getting about 40 t0 42 mpg and started using lubecontrol for 2 months now (btw Gearbox I havent noticed any drastic change yet???) Im at about 280,000+ miles on an 01 LX and still going with the original clutch and tranny. Almost forgot had a crack on my exhaust manifold but replaced it which another OE back when.
https://www.civicforums.com/forums/7...ml#post4245793
rzc is offline
Old 04-07-2010
Whachya lookin at?
BlueEM2's Avatar
Good suggestions above. Also clean your Throttle body sensors and valves, it's probably due and is always good to stay on top of. It can cause this problem. When you start the car up does it blow white smoke out of the exhaust? It's possible you have a head gasket issue and the coolant is seeping into your cylinders and burning up when you first start the car making it stumble.
BlueEM2 is offline
Old 04-07-2010
radar1's Avatar
The car does not smoke when this happens. I dont believe it would be a head gasket " no symptoms there" and I can drive it for an hour and shut it off for 5 minutes and sometimes it will do it and sometimes not. Coils checked out ok. Is the only fuel filter on this car in the tank? Auto parts store says it's in tank. If this was the problem wouldn't it run bad all the time "I'd think so" and more than likely throw a code? Thanks for the ideas
Radar1
radar1 is offline
Old 04-07-2010
Whachya lookin at?
BlueEM2's Avatar
Clean your throttle body sensors and valves. That's a great place to start and it's almost free. Just need some throttle body cleaner.
BlueEM2 is offline
Old 04-07-2010
if you see the rpm drop below 700 before it dies, its an idle issue and you should be checking the idle air valve and throttle body parts for carbon buildup. if the car drives fine sometimes, its not the fuel pump.
gearbox is offline
Old 04-15-2010
radar1's Avatar
02 sensor was the culprit. I'd never thought one could do this.
radar1 is offline
Old 04-15-2010
its possible, because when they get old, the response time drops. so pressing the gas quickly doesnt give the sensor enough time to send info back to the ecu. i noticed it too but wasnt bad enough to where the car wouldnt move forward. your check engine light shouldve come on tho if there was o2 sensor problems.
gearbox is offline
Old 04-15-2010
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
how much did it cost u to replace th O2 sensor?
lewal is offline
Old 04-16-2010
01-03 civic $50 each
04-05 civic $250 each
gearbox is offline
Old 04-17-2010
lewal's Avatar
thanks
lewal is offline
Old 04-17-2010
radar1's Avatar
How old is old? The car has 65k original miles. It would also start running rough just sitting in park half the time,"before driving it"; but I could shut it off and restart and it would run like a dream. Since I'm going back to school I didn't have the time to track the problem down and I didn't want to get stranded on the interstate so I took it to the best shop in my town. These guys are honest but expensive; cost 300 bills. OUCH!!!!! Just glad to get it fixed. Thanks for the suggestions.
Radar1
radar1 is offline
Old 09-01-2010
gudoffer's Avatar
gudoffer is an unknown quantity at this point
where do u buy the O2 sensor for 01 civic for $50?
my o2 sensor light doesnt come on, came on once and went away. but yea cars at almost 195 000 km and it sucks on gas, runs without power...
should i change my sensor?
gudoffer is offline
Old 09-01-2010
it will come on again, when the sensor gets old the response time goes down and thats why sometimes the light will come and go. its time for a new one. i got my bosch oem type sensors from advance auto for 01-03 civic. i can check part numbers but you should figure out if its the primary or secondary sensor thats bad.
gearbox is offline
mattdoc
03-14-2017 12:10 PM
CapYoda
11-11-2001 05:17 PM
Lightman
11-10-2001 06:44 PM
liljoe
11-04-2001 01:27 PM
HitlistCivic01
10-27-2001 07:47 PM
Quick Reply: 2001 civic intermediately runs rough
