Idle Air Control
Old 01-21-2010
dagua002's Avatar
dagua002 is an unknown quantity at this point
Idle Air Control
can anyone help me locate the idle air control valve, i'm having major problems.
i have a 2000 Civic Ex
thanks!
dagua002 is offline
Old 01-21-2010
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
Re: Idle Air Control
should be somewhere on the throttle body
Muirsy is offline
Old 01-21-2010
dagua002's Avatar
i'm fairly new to this, where is the throttle body?
dagua002 is offline
Old 01-21-2010
its the smaller piece screwed to the throttle body, where the two coolant hoses feed into. #2 in the pic, below the throttle body. throttle body is after the air intake, but before the intake manifold.
gearbox is offline
Old 01-21-2010
BLDNPSI Mod
tfnaaf's Avatar
whats the problem your having?
tfnaaf is offline
Old 01-21-2010
dagua002's Avatar
my car starts choking up as if it were going to turn off. and the check engine light is on and says there's a problem with the idle air control valve.
dagua002 is offline
Old 01-21-2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Don't buy a new IAC valve, you will be wasting your money. It's very rare that they need to be replaced. The check engine light is just telling you that there is a problem with the air system.
Most likely, the IAC valve needs to be removed and cleaned. Perhaps the throttlebody needs to be cleaned as well. Check to see if you are leaking air anywhere.
Oh yeah, and don't touch your throttle body idle screw.
Cleft_Asunder is offline
Old 01-21-2010
dagua002's Avatar
yea i'm not replacing the iac valve just yet. i'm taking it out and cleaning it first to see if that works. buying a new iac valve is my last resort. is there anything else that might be causing this?
dagua002 is offline
Old 01-21-2010
Muirsy's Avatar
nothing else i could think of... ur iac valve is just prob clogged. so just take it out n clean it
Muirsy is offline
Old 01-22-2010
You're going to have to take off the TB to get the iac valve since yours is at the bottom. I would clean the TB as well. Cover any sensors with a rubber band and a plastic bag (or whatever). Spray out the holes with carb or brake cleaner and make sure it's all clean. When you put the IAC back on, put a little oil on the seal so it expands a bit.
Old 01-26-2010
dagua002's Avatar
where can i find the o-ring for the iac???????
dagua002 is offline
Old 01-27-2010
got mine from honda dealer for around $2
gearbox is offline
Old 01-27-2010
dagua002's Avatar
i cleaned the IAC but it still chokes up but barely only at high rpms. there is a black piece in the IAC i wanted to know if that can be removed??
dagua002 is offline
Old 01-27-2010
RonJ's Avatar
RonJ will become famous soon enough
No part inside the IACV should be removed.
What specific OBDII code for the IACV is the ECU throwing? I ask because there is more than one, and troubleshooting for each code is different. In addition, the IACV is only one possible cause for an idle problem.
Finally, you mention that the engine bogs at high rpm. This does not fit with an idle problem and sounds more like misfiring. How old are the plugs, wires, cap, and rotor?
RonJ is offline
Old 01-27-2010
dagua002's Avatar
I went to atozone and the checked the code it came back with Idle Air Control problem i'm not sure the code though. what else can be the idle problem??? and i have no idea how old the spark plugs and wires are. and whats cap and rotor? i'm new to this so i might ask dumb questions
dagua002 is offline
Old 01-27-2010
RonJ's Avatar
In the hood fuse box, there's a 7.5A fuse labeled Back Up. Remove this fuse for a few minutes and then reinstall it. This will clear all CEL codes from the ECU. Then drive the car and if the CEL turns on and remains on, bring the car back to AutoZone to have them pull the CEL codes again. Post all retrieved codes in your thread.
If you don't know how old are the spark plugs, plug wires, distributor cap, and rotor, then you should probably replace them.
RonJ is offline
Old 01-27-2010
dagua002's Avatar
what spark plus and plug wires do you recommend? where can i buy the cap and rotor?
dagua002 is offline
Old 01-27-2010
There are many reasons idle could be off, not just the IAC valve. Air leak, coolant leak, TB/IAC valve dirty, head gasket. Your check engine light is pointing to one or a combination of these. I had a similar problem, same check engine light, and the problem turned out to be a combination of leaking radiator fluid, a vacuum leak, and a dirty tb/iac valve.
Old 01-27-2010
Honda, or napa autoparts sells a japanse cap/rotor. But the prices are about the same.
Though I wouldn't change it just yet. Check the cap and clean the electrodes. If it doesn't improve anything, it's unlikely to be spark related. NGK copper V-power plugs are just fine.
Old 01-27-2010
dagua002's Avatar
whats a vacuum leak?? i can clean the TB with the carburator cleaner??
dagua002 is offline
Old 01-27-2010
RonJ's Avatar
A vacuum leak would not cause a low idle.
Post your CEL codes.
Again, if you don't know how old the plugs, wires, cap, and rotor are, just replace them.
RonJ is offline
Old 01-27-2010
dagua002's Avatar
alright i will as soon as i get them
dagua002 is offline
Old 01-27-2010
dagua002's Avatar
my CEL never turned on but its still doing the samething. it chokes up while i drive but doesnt stall out or anything. any suggestions why it still might be happening?
dagua002 is offline
Old 01-27-2010
RonJ's Avatar
RonJ is offline
Old 01-28-2010
dagua002's Avatar
how do i clean the electrodes?
dagua002 is offline
Old 01-29-2010
alcohol and a cotton swab?
gearbox is offline
Old 01-29-2010
It won't get the corrosion off. You need a small flathead screwdriver to gently push the stuff off, but not so hard that you scrape into the delicate metallic electrode.
Old 01-29-2010
Low and slow!
02civicsi02's Avatar
Ok first of all dont always trust autozones codes, they give the right codes but there descriptions most the time is wrong. So you need to get the service manual for your car and the codes are under the fuel and emissions section. And it will show the page where you can diagnose the problem.
And the best way to get corrosion off is use some baking soda with water or coca cola.
02civicsi02 is offline
Old 01-29-2010
I forgot it's the same corrosion as battery terminals, duh. Baking soda ftw. (not to be confused with baking powder)
jc33312
05-12-2015 03:17 PM
crowtoo
05-11-2015 06:50 PM
Ninetyatecivic
05-09-2015 07:48 PM
carid
04-30-2015 07:00 AM
mievil
04-28-2015 11:02 PM
Quick Reply: Idle Air Control
