2003 civic EX Engine sputtering in idle with Check Engine Light
Rep Power: 0 2003 civic EX Engine sputtering in idle with Check Engine Light
Code shows p0300, p0301, p0302, p0303, and p0304,
Random misfiring of all cylinders
67000 miles, Any suggestions as to where to start?
Rep Power: 205 Re: 2003 civic EX Engine sputtering in idle with Check Engine Light
They have to be getting spark since he can start the car. It sounds like ignition though. I would check the cap and rotor for any severe wear or cracks. Also test the igniter as well since it's possible that it is not giving off enough spark per cylinder.
Also the timing may be bad and the spark is coming so late the engine is reading it as a misfire. If any work was done to it right before it happened or if you were in an accident, I would check everything that was touched. If you can remember what happened right before the CEL came on, that'd be a lot more helpful
Just had the same problem with my car.
My problem was the MAP sensor. I have a 00 auto
Not sure where your MAP would be located but mine was right behind the throttle body.
Hope this helps.
Feel free to ask if about anything
Xuhme
21
08-07-2023 03:40 PM
dooner24
04-14-2015 07:51 PM
deus-ex
04-13-2015 12:29 PM
bahena08
04-11-2015 05:09 PM
2001, 2002, 2003, 2004, check, civic, engine, honda, light, p0300, p0300p0301, p0301p0302p0303, p0302, p0303, sputtering
