You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
General Honda Civic Forum Archive.The archive is dedicated to storing threads for research purposes only, please place questions in their appropriate forum.
Car Clock flashing, won't reset after battery change
Ok, Here's what happened:
My car went in for some repairs. During repairs I guess my battery died and had to be recharged. Of course in the process my factory radio went into auto-theft mode and needed to be reset with the radio code.
Ok. So I got the radio code, Had to disconnect the negative pole of the battery because apparently the maximum tries to enter had been reached. Reconnected the battery, entered the code, radio is working fine, but my clock keeps flashing and won't set even when I follow the procedure to set it.
I don't know if this has anything to do with it, but my SRS light that usually just flashes for about 5 sec when I start the car, now stays for about 20 sec longer than usual, then turns off.
I have a 2002 Civic. Any Honda techs on here that can help me? The clock thing is bugging me because I thought getting the CODE was the difficult part, and now this.
Re: Car Clock flashing, won't reset after battery change
I would try disconnecting the radio for about an hour and see if that will reset the head unit. As for the airbag light, i the SRS computer maybe taking longer than usual to read its internal data. Was the car jump started?
if you stayed close to me i have a stock 04 and 05 civic ex radios.i have my books when i bought my car but they are in it and while im off of work im trying to be lazy.ill go see about it later today it is like over 90 degrees today its hott. my airbag light stays on too but it could be caused by the truck that hit me from behind at a red light a couple of years ago. it did little damage mostly to the trunk. did you ever have a fender bender?
2002 Civic EX
Similar problem here! After changing battery, the "code" letters display when I turn the radio on. IF I push any of the buttons for selected stations, I get an error code 1,2,3,4,5,6,7,8,9, and/or ERRE. Radio/CD does NOT work. I read in manual it takes a "few days" for things to reset after changing the batter, but it has now been about 4 weeks.
