Help W/Rear Brake Light Bulb Replacement
Old 03-10-2009
splaceca's Avatar
splaceca is an unknown quantity at this point
2006 Civic-EX, For the life of me I have tried to remove the screws in the truck holding the truck lining to get at my tai lights. The screws turn like there is no tomorrow but never appear to loosen. There must be trick to this since I have done this before with many other vehicles but alas the Civic is giving me fits. I have three of my friends try and short of trying to ripe out these buggers I was hoping someone who has done this can give some help. These are the original items so it seems silly they are so much hassle.
splaceca is offline
Old 03-10-2009
sl33pyriceboi's Avatar
Re: Help W/Rear Brake Light Bulb Replacement
are u talking about the brake light form the tail light, or from the 3rd brake light?
sl33pyriceboi is offline
Old 03-10-2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
06 EX and up the 3rd brake light is LED. not replaceable. well as far as a bulb goes.
yea if your talking aobut those screw facinors where the screw wedges apart the plastic on the othersidem those can be a real pain. i've rounded mine down with a little sand paper. just enough to hold them in but mone more or less slide in and out now. just use a small flat screwdriver to pry up the screw while your twisting it out.
DieMaster is offline
Old 03-11-2009
pretty sure you can pry them out. its like a fake screw. just turn gently without pushing into it. that usually works, otherwise you can prolly pop it out.
gearbox is offline
Old 03-11-2009
splaceca's Avatar
The question pertained to accessing the bulbs for the rear brake lights. The answer seems to be do not apply pressure when turning. Got two of the three I needed removed out. The other I had to pry out, I have to assume that it got gunked up as this was the first one that we tried to remove. Both of the component parts are straight plastic junk. Thanks to all that replied and the info on the LED on the third brake light.
splaceca is offline
Poopies
04-20-2017 11:36 PM
bsmiley
04-27-2015 01:27 PM
thesushiboy
04-12-2015 02:54 AM
DaPipeLayer
11-14-2001 08:06 AM
disaster
11-07-2001 05:30 PM
Quick Reply: Help W/Rear Brake Light Bulb Replacement
